You need to find a new shop. End of story.
Can cams be installed incorrectly?
Originally posted by graphikg View PostSharks, can I speak to you more about this and possibly even have a conversation with you over the phone? Just to let you know, my Vanos is rebuilt, and we have also tried another used good vanos just to make sure and it has still been the same problem. What are the chances that two different Vanos units have the same problem?
pm me if you want give me a call
^This. Should be 8mm IIRC off the top of my head. i believe the bentley will tell you, the TIS def will.
Check Us out on Facebook
Full Product Line Tuning
or is the cam sensor pickup on the cam installed correctly?
Originally posted by graphikg View PostMy car may be the only s5x/m5x that has had these symptoms and who's mystery has not been solved. I have no other ideas but literally change the motor entirely.
I decided to time the cams without block tool, no dial indicators.
I put the crankshaft at TDC mark. Put the gear on the exhaust side, put chain tensioner in. Alonged the exhaust gear to be in the center of the holes with tensioner fully installed. Then I installed the intake sprocket with chain with holes in the middle. The A and E markings should be facing up on the back of the cams. Then I bolted both sprockets and carefully watched that they don't move. Then I turned the sprockets fully clockwise then installed the vanos and kept turning the sprockets counterclock wize until vanos gear fully in. The intake cam square will look slightly retarded, and vanos gear is all the way out (bottomed out at the vanos unit).
Summary: Timing blocks are preventing proper vanos gear install, causing the gear to advance intake cam by one tooth. Solution: Remove timing blocks prior to installation of vanos unit. Once vanos unit is installed the intake camshaft should slightly be off to retarded side. Thats because at this point vanos gear is bottomed out, soon as the vanos piston get some oil it will correct the intake cam timing.
Thats what fixed my problem.
Originally posted by EduardoGomez View PostI had the same problem. Cause is intake camshaft is too advanced(vanos unit installed one tooth too advanced). On some cams the block tool does not work right.
Originally posted by samiam3356 View PostThat would be hard being that it's usually tied in with the MAF connector BUT i guess possible.
I couldnt get past 3300 rpm and the car would just die while giving me a HORRIBLE grinding, metal "screaming" sound. It sounded like my car had a short exorcism when it died at 2800-3300 rpm. Was this what you were getting? But with the vanos disconnected, it is practically perfect minus the extra vanos push. If you have the solution it would be my most grateful e30 news.
