E30 24V Intake Set-Up
  • bubbajan21
    • 1962
    Originally posted by balooshinakus
    This thread contains the pictures of my airbox from castros:
    http://www.r3vlimited.com/board/showthread.php?t=185577
    I love that setup, I want one! I'll PM Castros about it. How do you like it?
    EDIT: I just saw that the last post to your thread and to the E30polak FS thread was in 2010. Does anyone know if they still make this? I sent both E30polak and Castros a PM, but I havent gotten any response.
    • Jand3rson
      • 37587
      Originally posted by kalib0y
      I honestly found the ka motors a little restrictive. Like the inlet was too small at least for my s50. So I did some experimenting before I sold it because I have a 3.5hfm now.
      Try unscrewing the front tube and front cover but leave the carbon fiber shield. Also remove your headlight cover. I found that my car had improved response, felt faster, and had a deeper sound. Try it and let me know.
      If ka motors made a 3.5in intake, I would buy it and not use the front cover and tube.
      I'm actually probably going to remove that front cover and shorten the CF tube by about an inch. I don't know if I got a different intake boot than most other people do, but it seems really long, and the end of the Kamotors intake is right up against my core support, where the headlights mount. There's pretty much no where for any air to go into at all.
      • bubbajan21
        • 1962
        Thanks for the input guys, I ended up ordering an airbox from Castros. I will post back here once it is installed with my opinion of it.
        • atldohc
          • Nov 2008
          • 359
          i made a heatshield for my car a few weeks ago. the design doesnt seem to be too different from the castros one. im sure youll be happy with your purchase as it looks like they make a quality product. on my own car the shield seemed to help smooth out the power, and as its been getting hotter this past week i havent been noticing the huge power drop i used to get when the temps went up
          • Skafrog
            • 1730
            I love this set up. Might want to re position your maf. Its been proven that you get a better tune if your maf is positioned at 10-11 oclock (you standing at the front of the car). I've searched it and found a lot of info on bimmerforums. Just never found out why but it works for me.
            That's 100% pure snake oil. Why would the clocking matter? How does a MAF operate?
            NASA MidSouth TT Director / GTS2 #018
            Mods: Coastal PS Fluid, 10w40 Oil
            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
            • giantkeeper
              • Aug 2009
              • 1416
              I am running a 3.5" maf and samco intake boot with ITG filter.
              Tight on space for sure. I cut the intake boot in half and used the non throttle body side for mounting my filter to the maf. Definitely need some sort of heat shield though.
              Always Always go for the reach around if there is an option
              • kalib0y
                • Dec 2004
                • 3620
                I thought so too till I spoke to the TRM guys and a few others even on BF.c
                95 7.1L 16V E36 M3
                Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                LIKE my Facebook Page! CLICK HERE
                • bubbajan21
                  • 1962
                  What is it that they say is better? Is it dyno proven HP / TQ, better throttle response, better fuel economy... Basically how do they quantify that it is better?
                  Do you have any pictures? I already bought an intake, but I'd still love to see some pics.
                  • giantkeeper
                    • Aug 2009
                    • 1416
                    Here you go
                    I will ultimately shorten the filter side of the samco boot I cut and then add a heat shield.
                    • bubbajan21
                      • 1962
                      Very nice intake, it needs a heat shield though. Can you comment at all on the Samco boot? I looked at buying it, but couldn't find enough evidence to prove to me that that little piece was worth the $70 or $80 that it sells for. Any input on it positive or negative? Is it worth the price for whatever benefits it gives in your opinion?
                      • giantkeeper
                        • Aug 2009
                        • 1416
                        Smooths out airflow - otherwise it's just a mod :D
                        I don't like the price, and could not argue the benefits either way.
                        Heat shield is coming, no doubt!
                        • 328ijunkie
                          • May 2007
                          • 3961
                          True and false lol
                          It depends on the intake setup to where its clocked but yes it matters. You basically want it so the actual element is sensing the smoothest airflow.
                          Check Us out on Facebook
                          Full Product Line Tuning
                          • Jszy25
                            • 352
                            Originally posted by Yeee30
                            can't go wrong with a stock airbox
                            1.
                            Which car is this airbox from originally?
                            91' 318is - OBDI M52/ZF swap w/ S50 cams
                            • e30shmobberr
                              • 1934
                              i am pretty sure its just a modified e30 m20 one
                              Patrick - IG:niicknac
                              RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                              • Yeee30
                                • Nov 2005
                                • 799
                                ding ding ding!!!!
                                hows ur swap coming along?
                                [PAKSIW]
                                20D .........
                                vmwerks :up:
                                ryan gmw :up:
