FYI - some N52 oil pan research
  • 328ijunkie
    • May 2007
    • 3961
    #106
    standalone running valvetronic? only the very very top dollar ones maybe
    Check Us out on Facebook
    Full Product Line Tuning
    • jntar
      • 459
      #107
      True, however valvetronic can also be locked at full lift manually with a block off plate and a traditional throttle body or bodies can be added.
      M42 turbo build.
      http://www.r3vlimited.com/board/showthread.php?t=301330
      • jntar
        • 459
        #108
        Originally posted by nando
        Im pretty sure the stock ecu is very doable. Ill get to it eventually.
        Imo, 95% of the time standalone isnt going to be as good as the stock computer, and the cost will always be higher.
        If you're serious I suggest giving RMP Motors a call. They are producing some crazy n52 race cars.
        M42 turbo build.
          • 34839
          #109
          Why bother with the n52 then? Isnt valvetronic kinda the point?
          A race car is the 5% of the time when it makes sense. The motor will mostly be at WOT, low end drivability a fuel economy dont matter.
          • jntar
            • 459
            #110
            I have no intentions on swapping an n52 into my e30. I'm just providing info on what "could" be done.
            M42 turbo build.
            • 328ijunkie
              • May 2007
              • 3961
              #111
              Most of the crazy N52s ive seen people building out there have it locked out and run off a cable TB.
                • 34839
                #112
                yeah, but those are race motors. I thought the context here was a swap for a street car.
                • 328ijunkie
                  • May 2007
                  • 3961
                  #113
                  As did I. locking out valvetronic is far from ideal for a street car, esp given the intake manifold and everything is designed around not being under true 'vaccuum'.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    #114
                    Shouldnt most standalones be able to actuate the valvetronic?
                    If you can use the factory ECU though...do that for sure!
                    -Nick
                    M42 on VEMS
                      • 34839
                      #115
                      maybe physically but software support will be limited. there's not going to be a "valvetronic" table in most standalones or dedicated outputs for them. Ones that have that will cost more than a nice E30.
                      and everyone always forgets about the cost for tuning. if you pay $10,000 for a computer you're not going to get the thing tuned for $0..
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #116
                        Exactly, I just meant you would most likely use a pwm output to control it. You would be on your own though to come up with a control strategy.
                        This is why even if a standalone COULD control things, you are way ahead just using the factory ECU if possible.
                        -Nick
                        M42 on VEMS
                          • 34839
                          #117
                          Bump.
                          So, it turns out MSV70 is pretty easy to hack. It's set up a lot like the motorsports DMEs. I don't have an EWS delete yet, but you'd only need a couple modules to make it happy. Who wants to try it? :p
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #118
                            You BDMing into it?
                              • 34839
                              #119
                              yeah, but you can do it over OBD as well, it's just a lot slower because of BMW's anti tuning methods (slowing down the write speed so it takes like half an hour to flash).
                              BDM takes about 1 minute for a complete flash, and with careful procedures you can do it with the DME still in the car without freaking out the CAS.
                              this one I think I can develop my own performance tune for. Also, I did a compare between my 330i and my wife's 325xi, all the addresses are exactly the same, so if I get her a 3 stage manifold I can literally copy and paste my stock tune over hers.
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #120
                                What software you using to write over OBD?
                                edit: Ive gone through the A2L pretty thoroughly and the 3 stage conversion seems relatively simple.
                                The 2 things that make it easy to compare are the Z4 3.0i and 3.0si 0da files.
