Post Your M/S5X 24V Swap Setup
This is a sticky topic.
  • Navarone
    • Jun 2014
    • 935
    #91
    Just ban me now.
    • Nick_S
      • Apr 2011
      • 3655
      #92
      Originally posted by Nick_S
      Re-posting mine since I'm done and it's running now.
      1. Engine
      - 92 e36 M50NV. E34 pan and pick up All stock for now. A/C & PS delete.
      2. Engine Wiring- E36 harness, adapter from Nando. 403 DME, Dinan Chip
      3. Drivetrain-
      G240, M42 dual mass flywheel, OE M42 Sachs clutch, G240 TOB and slave, 4.10LSD, E30 mounts. e36 325i driveshaft
      4. Shift Lever and Linkage
      - euro 320 shift arms, UUC shift lever, new bushings
      5. Motor Mounts
      - E28 green mounts, E36 mount arms
      6. Brake Booster- stock, bone stock. Not even moved. Clearance is tight, about 1/4in but it doesn't hit it so why bother?
      7. Steering System- E30 rack with condor PS delete plate.
      8. Cooling System
      - M42 radiator, new thermostat and 80C aux fan switch. Will be running a spal pusher eventually
      9. Exhaust System- OBD-1 headers to E36 y-pipe. Had my existing exhaust trimmed and bent to meet the y-pipe. Super super simple. New bosch 02 sensor.
      Just a quick update. 18K miles later and all I've done is a belt tensioner, new coils/plugs and oil changes. Still loving the car! Thinking about looking into an S50 for next year though or a low boost turbo.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • spiDmang
        • 3941
        #93
        1. Engine
        S52B32: fully functional obd2.
        Stock s52 cams (intake/exhaust)
        rebuilt/flow tested/ultra sonic cleaned pink top injectors
        E39 528i fuel rail with built in FPR (I can run the vanity cover, no problem, with no modifications. Awesome part but super hard to find)
        3" stock MAF
        K&N 9in cone filter
        e34 oil pan with stock baffle
        Red locktite'd and safety wired oil pump nut
        2. Engine Wiring
        RobertK @ Kadunza rewired my E36 wiring harness. Easily the best part of the swap. Everything was labeled, and stretched to the proper lengths to insure proper fitment. Fired up literally first try with no CEL's.
        3. DME
        Dave Markert @ Markert Motorworks reflashed my DME.
        We removed...
        -SAP
        -EWS
        -muffler valve
        -vehicle speed signal requirement (for 87 325i/iS)
        -bumped the redline
        4. Drivetrain
        Getrag 260, fully resealed and hot tanked.
        M20 single mass LTW flywheel (11lbs)
        Sachs Spec 2 M20 Clutch and Pressure Plate. rated for 400hp
        E30 325i throw out bearing and pilot bearing
        E30 325i clutch slave cylinder
        E30 325i clutch master cylinder
        E30 UUC Stainless Steel Clutch hose
        Custom trans brace
        E21 Trans Mounts
        Manual e30 driveshaft new CSB and Guibo
        3.73 LSD (70mph = 2,900 rpm)
        5. Shift Lever and Linkage
        UUC Evo3 shifter
        UUC DSSR (with 10degree twist)
        late model selector rod joint (to fit DSSR)
        Garagistic Delrin bushings, front & Rear
        ZHP Shift knob
        6. Motor Mounts
        E28 M5 Motor Mounts
        7. Brake Booster, Master Cylinder, and External Reservoir
        Zionville Reman'd E21 booster
        E32 25mm Master Cylinder...going back to stock 325i. With the smaller booster, and bigger cylinder, the brakes are harder than Peter North's dick...seriously, not good for daily driving
        318iS brake booster check valve
        8. Steering System
        Stock e30 steering rack
        New E30 power steering lines
        E36 power steering pump and reservoir
        9. Cooling System
        M20 late model radiator
        Normal M20 spider hose.
        80C thermostat
        OEM Aux fan with 80C temp switch
        10. Exhaust System
        Stock OBDII exhaust manifolds
        Downpipes cut at flange and rewelded onto custom downpipes.
        2.5' single piped exhaust
        Vibrant ultra quiet resonator
        Vibrant 1040 street muffler
        91' 318iS - S54/6MT Swapped
        08' E90 M3 6MT - Daily
        Originally posted by IronJoe
        Originally posted by 2mAn
        • mistacarder
          • Jan 2013
          • 289
          #94
          Engine- 95 s50b30 completely rebuilt, CP Pistons, arp hardware, achillies motorsports oil pump shaft
          Engine wiring- E36 harness with 318 wire cover wired by kadunza. red413, Dinan Chip
          Drivetrain- ZF that came with the s50, e30 driveline, revshift guibo adapter, e21 mounts with aluminum cups
          Shift Lever and Linkage- Nardi shift knob, AC Schnitzer short shifter, new bushings
          Motor Mounts- E28 mounts, E36 mount arms
          Brake Booster- E21 booster with stock madter, abs deleted
          Steering- e30 rack, PS delete
          Cooling- m42 radiator, electric pusher fan
          Exhaust- stock obd1 manifolds I will be using a aftermarket catco cats with magnaflow muffler hopefully it will pass bar inspection!
          Instagram: @mistacarder
          • pandaboo911
            • 2070
            #95
            S52b32: Obd1 converted
            Obd2 fuel rail
            Obd2 throttle body
            Elring headgasket
            Arp head studs
            Recut valves & guides
            Vortech V2 S trim w/ straight cut gears
            6" crank pulley + 3" drive pulley = 15psi @ 7k rpm
            ESS Supercharger bracket
            Sillicone intakes water-air intercooler
            Rally Road oil cooler cap
            Earl's 6AN oil cooler
            Walbro 400 E85 Fuel pump
            318is transfer pump
            Fuelab 6 micron e85 filter
            1/2" aluminum fuel feed line
            2. Engine Wiring
            S50 manual harness
            Early model 17 pin c101
            3. DME
            506 DME
            RK Tunes chip
            4. Drivetrain
            Zf320
            E21 trans mounts
            eBay 11lb flywheel
            Oem Sachs PP / Clutch - still holds 400wtq 😎
            Oem Guibo
            E36m3 manual driveshaft
            2.79 LSD from a 325es
            AKG dtm style chassis mounted shifter
            Stock single shear linkage
            Shifter brass bushing, trans rubber bushing.
            6. Motor Mounts
            E28 M5 Motor Mounts raised 1/2" with spacers
            Porsche 944 booster
            325e non-abs master cylinder
            Stock reservoir
            Rear line lock for sweet burnouts
            8. Steering System
            E46 325i ZF steering rack, same ratio as 330ci
            Relocated steering reservoir
            9. Cooling System
            Koyorad e36 m3 radiator
            Stock e36 thermostat
            SPAL 16" pusher with 88C temp switch
            Relocated e30 expansion tank
            10. Exhaust System
            Raceland 24v swap manifolds
            H pipe
            2 Walker '95 e36 cats
            Y pipe
            3" eBay resonator
            Borla XS muffler
            • sneakyRedPanda
              • May 2015
              • 133
              #96
              Originally posted by pandaboo911
              *snip*
              That relocated late model coolant reservoir is absolute money. Did you have to fab mounting points or is there an easier way? Where do you run the lines?
              • pandaboo911
                • 2070
                #97
                Yeah some angled aluminum and the original black tab thingy?? holds it down. The aluminum is fastened to the battery tray. The hose runs behind the engine, over the trans bell housing. The overflow runs through the wiper/blower motor area. Just some rubber hose wrapped in fire sleeve.
                • s14brent
                  • Mar 2014
                  • 569
                  #98
                  1. Engine
                  S52B32: OBD I converted
                  TMS 24lb injectors
                  3.5" Bosch 800 MAF
                  e34 oil pan with achilles baffle + welded oil pump nut
                  2. Engine Wiring
                  95 M50 harness
                  wired by myself
                  3. Drivetrain
                  ZF 320 manual trans and driveshaft from a 328i
                  ebay f1 stage 3 clutch and chromoly flywheel
                  E36 m3 clutch slave cylinder
                  E30 325i clutch master cylinder with brand new hard/soft line
                  UUC poly transmission mounts
                  3.73 LSD
                  z3 shifter with akg shifter bushings and dssr
                  Condor shift knob
                  5. Motor Mounts
                  AKG poly
                  6. Brake Booster, Master Cylinder, and External Reservoir
                  E30 booster (shoulda went porsche...oh well)
                  E30 master cylinder with stock reservoir
                  M50 manifold was modified /shaved for extra brake booster clearance
                  7. Steering System
                  e36 m3 rack
                  8. Cooling System
                  mishimoto e30/e36 aluminum radiator
                  m52 coolant hard pipe
                  16" spal puller fan
                  9. Exhaust System
                  ebay headers
                  custom 2.5" exhaust being mocked up now.
                  89 325i 4dr s52
                  02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
                  21' Toyota Tacoma TRD OR 4x4 6 speed Manual
                  • WAM3
                    • Aug 2016
                    • 28
                    #99
                    1. Engine
                    - Euro s50b30
                    2. Engine Wiring- E36 M3 custom adapted 075 DME, Alpha N Tuning
                    3. Drivetrain-
                    E36 M3 ZF 5 speed. E36 M3 dual mass flywheel, 2.93 LSD, Rebuilt driveshaft
                    - previous owner short shift kit install.
                    5. Motor Mounts
                    - AKG S50 poly mounts
                    6. Brake Booster- e28
                    7. Steering System- E36 M3 Steering Rack
                    8. Cooling System
                    - E36 M3 radiator, not running stock oil cooler.
                    9. Exhaust System- Ebay headers with custom fitment, hiflow cat (unable to fit euro headers without more work). Fuelmiser o2 sensors.
                    10. Intake System- Custom Carbon Airbox with built in filter. Alpha-N mode, not using MAF.
                    Save
                    • Yezus_Krys
                      • Feb 2016
                      • 80
                      #100
                      So my car is a work in progress as I am also doing big turbo in my GTI. Here's what I have so far.
                      Car: 1991 318is
                      Donor: 1999 M3, 143k perfectly running car
                      Parts taken from: 1999 Z3 2.8, E34 525i, E36 328i
                      Engine
                      - S52B32 OBD1
                      - M50 Manifold
                      - M50 Fuel Rail (considering switching back)
                      - Pink Injectors
                      - E34 oil pan
                      - Some ghost tune I had a buddy flashed with EWS delete
                      Engine Wiring
                      -Andrew's wiring harness adapter. Car was auto so will be getting rid of extra wires.
                      Drivetrain
                      - Z3 2.8 ZF trans. Stock clutch, flywheel and pressure plate.
                      - Z3 2.8 LSD 3.15
                      Suspension
                      - E36 M3 5 lug conversion up front(not installed)
                      - Z3 2.8 rear trailing arms(not installed)
                      - Eibach lowering springs(not installed)
                      - SACHs rear struts from a E36 328i
                      - E36 328i generic rear strut brace
                      Mounts
                      - Condor Bushings Engine and Trans. Having difficulty aligning the engine mounts but will try again soon.
                      Braking
                      - E36 M3 Front Brakes (Hubs, rotors, calipers, pads)
                      - Z3 Rear Brakes
                      - 944 Brake booster ( had the stock clevis welded to it)
                      Steering System
                      - E36 M3 steering rack with fresh tie rod ends. No spacers were needed however I have to shave the steering rod hole at the bottom. It was touch slightly.
                      Cooling System
                      - Mishimoto E36 radiator. Plan to run an E-fan in front of the condenser.
                      - E36 M3 hoses for now.
                      Exhaust System
                      - EBay SS headers
                      - Remus muffler
                      Sent from an Abacus
                      • jotam3
                        • Mar 2014
                        • 47
                        #101
                        Originally posted by spiDmang
                        10. Exhaust System
                        How do you like your exhaust setup? I'm gonna be at that step soon, S52 with stock headers. And have similar parts, Vibrant 1149 Muffler and Vibrant 1141 2.5" Ultra Quiet Resonator and wondering how it's going to sound. I was originally planing on going from the headers to two individual 2.5" pipes with an x-pipe, then the two pipes to a Y-pipe and into the resonator, and single pipe the muffler. But, if yours sounds good, I may be able to mimic yours instead.
                        • sslum
                          • Jan 2017
                          • 3
                          #102
                          Curious on avg price for this swap/build
                          Looking to swap the e30 still figuring out my path. Depends on what I can get my hands on! Also what anyone would recommend. Find an s5x full setup or build from m52 block?
                          sigpic1989 Cirrusblau Metallic Sedan
                          S5X build in the making
                          More Doors More Love
                          • mjweimer
                            • Dec 2015
                            • 648
                            #103
                            +1 I would like to see some pics of the modified manifolds and custom downpipes. Also very interested in the noise level with this set-up.
                            The exhaust manifold to downpipe connection is the only area of my M52 swap I have not quite figured out yet.
                            • trout
                              • May 2014
                              • 33
                              #104
                              i'm still putting mine together, but i'm using an arcasylum modified subframe with stock s52 headers and downpipes
                              • mjweimer
                                • Dec 2015
                                • 648
                                #105
                                trout - thanks for sharing. That ArcAsylum piece looks beautiful - hope it's not too spendy.
                                MJ
