M3 Flywheel Confirmation
  • Northern
    I like cupcakes & sh!tboxes
    • 5278
    Also noteworthy that all the starter rings for the I6's are the same diameter, giving a nice visual reference point.
    Based on the distance from the starter ring to the friction surface, I'd bet money that yours is 240mm vs 228mm like the RHD M20 flywheel below:
    Originally posted by priapism
    Originally posted by shameson
    • JimmyP
      • 394
      I just edited my post, I was unaware there were a couple non-M 6s that used the 240mm clutch (1995 - 11/95 E36 323i - 6 cyl & 1994 - 99 E36 328i w/ M50, M52 2.8L - 6 cyl)
      Jimmy P.
      87 E30 M3 Prodrive British Touring Car
      88 E30 M3 Zinnoberot - Garage Queen
      88 E30 M3 Lachsilber - SCCA SPU #98
      92 M Technic Cabrio - S14 Powered!
      98 318Ti Morea Green
      04 Ford F350 Dually Tow Machine
      • ForcedFirebird
        • Feb 2007
        • 8300
        Originally posted by Northern
        Also noteworthy that all the starter rings for the I6's are the same, giving a nice visual reference point.
        The ring gear for both 24v clutches, yes, the m20 is different (your pic is m20). That's why when using a Getrag in a 24v swap we need to use the m20 starter.
        john@m20guru.com
        Links:
        • ForcedFirebird
          • Feb 2007
          • 8300
          Anything that got the ZF should have the 240mm clutch. From what it looks like on realoem, the euro 323 got zf, USA got Getrag.
          http://www.realoem.com/bmw/enUS/part...993&series=E36
          john@m20guru.com
          Links:
          • Northern
            • 5278
            I should've included the word diameter in there, fixed.
            Also a good point that you can tell which engine it's from by the gear cut. I didn't quite make it that far.
            • TobyB
              • 5287
              I was just going to say that it looked like a gripfarts I pulled out of the E46...
              t
