Ews Iii
  • Jason89i
    • Sep 2004
    • 875
    Originally posted by Teaguer
    Jason you weasel
    hey, thanks for the kind words.
    when did you score a Euro S50 ?
    3.0 or 3.2 ?
    56k mile euro s50b32. bought in january???? its now installed. assuming all goes well, it comes home tuesday. im like a kid at christmas. cheers, jason
    • Teaguer
      • Sep 2004
      • 6167
      Sweet man . :up:
      Looking forward to some pics .
      What tranny and rear gear are you using for this engine ?
      • Jason89i
        • Sep 2004
        • 875
        im running the 5spd zf and an mcoupe 3.15 or 3.23 diff.
        before i get accused of thread jacking......
        here is the pic of the ews2 mounted in my car. I made some brackets to hold the ecu, ews2, borg, antenna and key. i kept the ignition lock from the e36 as it was a good housing for the antenna ring and key. the engine harness was a right hand drive car, so the harness didnt have much room to extend the ecu very far into the glove box. cheers, jason
        • EtaSport
          • 2853
          Lots of good info here. The 98 e36 would still use the EWSII system. System components include: key with transponder, ring antenna, transmitter/receiver module, ewsII control module, dme control module
          The big thing is the individual serial number that is stored in the DME. The key is coded to the ews, and the ews is synched to the dme. If the ISN in the ews matches the ISN in the DME, then fuel and spark can occur.
          Also remember as long as the key is coded to the ews the engine will crank, but will only run with verification of the ISN.
          only 10 keys can coded to an ews, so depending on how many keys had already been coded to that particular ews, its possible that no more keys can be coded to them at some point. The EWS is vin specific, but the DME is not and can be programmed using the GT1.
          Old and improved:
          • jrez
            • Oct 2005
            • 71
            Just like the guys have said here, except I mounted my antenna ring/key into the driverside under dash cover.
            I can remove the key when needed, so I got the "immobilizer" discount from the insurance company.
            At the race track.
            • moatilliatta
              • 6152
              How would you by pass EWS III all together?
              @Zakspeed_US
              • nrubenstein
                • 3148
                You fork over lots of cash.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • matt
                  • 3732
                  Need to have the DME reprogrammed to bypass any of the different EWS-es.
                  • JGood
                    • Jan 2004
                    • 7959
                    Found a nifty PDF which is relevant to this topic. Posting for my future reference as well:
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • moatilliatta
                      • 6152
                      Could a gt1 or autologic computer re flash it? Also I know some wiring is needed. More than ewsII. I knew this isn't going to be a walk in the park.
                      Excellent literature ;)
                      @Zakspeed_US
                      • matt
                        • 3732
                        No, neither of those. It needs to be custom software. What kind of motor is it?
                        • moatilliatta
                          • 6152
                          m57 has dde 4.0
                          Maybe a 7 789 376 DDE?
                          @Zakspeed_US
                          • EtaSport
                            • 2853
                            A diesel? What are you putting that in? I think it's stupid that bmws diagnostic and programming software can't do thing like that
                            Old and improved:
                            • moatilliatta
                              • 6152
                              e34 touring that currently has the m60b30
                              tired of 15 mpg
                              @Zakspeed_US
                              • MattM
                                • Apr 2009
                                • 931
                                m57 has dde 4.0
                                more details/pics? build thread? i have never heard of a swap of sorts
                                Full Build Thread Here
