The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • Beau B
    • Mar 2004
    • 734
    #361
    The HFM does not need to be at 10 o'clock. I couldn't figure out how changing the position would matter so I called Pete McHenry and asked him. He told me it doesn't matter and he places his at different positions. Take it as you will.. Oh and I also checked my mom's M Roadster today and hers is at 3 or so...
    Beau
    1988 BMW 325iS
    • Ryan Stewart
      I Love Miatas
      • 8978
      #362
      Dunno but I may give cleaning it a shot. I wonder what to do with the HFM?
      Im now E30less.
      • sentrase00
        • Sep 2004
        • 30
        #363
        yeah I have heard that it makes a difference but that is just butt dyno i guess. It could be in your head. would be interested to see it dyno'd. Im sure when I am done when my swap I can dyno it for free, so I will give it a shot. But I dont know when I will even start the swap. I just started buying things, but I guess I will start this project in march.
        2007 Honda Civic Si
        looking for another e30
        • Brew
          • 3060
          #364
          Well, the guy who started the thread I posted is claiming that he had it dyno'ed and that it made quite a large difference. There is definitely a lot of speculation on the subject, but its an easy enough thing to mess around with that its worth a shot.
          '91 318is
          • ed94r
            • Mar 2004
            • 382
            #365
            Beau
            Just food for thought: The Mroadster has the obd2 3" HFM if it's stock. All stock 3" E36 HFM locations seem to be 3 o'clock. BUT, I'm specifically talking about the Euro 3.5" (or it's substitute, the 540) HFM. Look at a 540 engine bay (ebay is good) and you'll notice that the HFM is at 10 o'clock. I don't want to pass misinformation, but I think the euro E36 HFM is also at 10 o'clock. Soooo, it just may be that the euro (and 540) HFM may be designed to work @10.
            I tried 10 again today, and it seems to loose some bottom end pull (to the 3), but it pulls to 7200 with more power. I swear it does!!
            Ed ( gonna stick w/ 10 for a few days and see if the DME adjusts to it better)
            1988 E30/S50...now with S52; Track
            1994 Miata R; ES Solo2
            1998 Lexus LX470; Wife (Slee'd anyway)
            2002 BMW 530i; A+ Commuter
            2002 BMW 325iT; Sport/Premium 5-speed
            2011 21' EconoTrailer
            • Beau B
              • Mar 2004
              • 734
              #366
              Beau
              Sorry I did not realize you were talking specifically about the 540 hfm. I dunno, I guess I just do not undestand how it makes a difference. I mean either way the filament, is still centered in the aiflow. I guess one way to see is to look up the 540 in BMW's service manual, and if it needs to be at a specific location it would say there. :?:
              Beau
              1988 BMW 325iS
              • Funkmasta
                • May 2004
                • 7185
                #367
                This is speculation on my part, but it is my belief that the positioning matters on the hot film MAF, I think the hot-wire MAFs could care less.
                This is an interesting tangent...
                Joe Funk -- Portland Oregon
                That Guy.
                03 X5. 3 liter obviously.
                • tranceguy
                  • Aug 2004
                  • 139
                  #368
                  Does a '90 325 have a C104? Anyone have a picture?
                  VANOS FOR LIFE MAING
                  • Addissimo
                    • Mar 2004
                    • 1820
                    #369
                    okay, so i wired the fuel pump directly to the battery to see if it works... it does... I then re-attached all of the hoses and everything and primed the line. I attached the supply to the silver and the black to the return. I tried to start my car with the pump running and still no go. I'd imagine the next step would be spark, but my book is a piecer and it doesnt even say what the socket size is that I should use for the plug. How would I check to make sure the injectors are working properly?
                    Any other ideas as to why she wont start?
                    Thanks,
                    Addis
                    Doing something M50 related? -> http://www.addissimo.com
                    On Myspace? ->http://groups.myspace.com/r3vlimited
                    BF2142 SN = BillyGoose
                    • Bryson
                      • 1490
                      #370
                      m50s are smart, if you aren't getting any spark, then they won't supply power to get gas. If you directly gave fuel then you likely have a spark problem. Have you checked the crank position sensor? That would be a very vague start. I'd also recommend consulting your local mechanic, we don't bite
                      • tranceguy
                        • Aug 2004
                        • 139
                        #371
                        Thanks,
                        Addis
                        Check to make sure you're getting power at your DME and that your main relays (group of 3) are turning on. Do your power windows/sunroof work? I had the same problem in the begining. I forgot to hook up the small green wire that splices in with the large green wire just before the engine plug.
                        • Mitch M
                          • 881
                          #372
                          Vanos & Non-Vanos Interchangeability
                          Can't find this in any archives. Will a non-vanos head work on a single vanos 98 aluminum 2.8 block?
                          • Bryson
                            • 1490
                            #373
                            in short, yes
                            • Addissimo
                              • Mar 2004
                              • 1820
                              #374
                              Okay, so my windows dont work, and I'm not getting power to my ECU... at least i dont think. I took a multimeter and grounded it to the car, then tested each lead on the ecu connector. I got a few weak ohm readings, but no voltage readings. What green wire are you talking about? Is it engine side or chasis side? I remember there being a couple green wires coming from one of the pins on the e30 wiring harness, i just spliced them together on the same wire on the e36 side.
                              Bryson-
                              I dont know exactly what you want me to do with the crank position sensor. It looks like its in the right spot, if i cant figure it out with the wiring harness, should I take the intake manifold off and follow the wire to where it connects? While i'm doing that I guess i could/should inspect the knock sensors too...
                              • e9nine
                                • 1890
                                #375
                                For your windows, check the wires on your starter...when I had my 2.7i done a wire came loose and the windows and some other stuff didn't work.
