The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • A_Whelan
    • Jul 2010
    • 691
    #1111
    Host your images online with an easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
    r3vlimited Lanyard Group Buy!!!
    • Wishno87
      • 6025
      #1112
      Looks like just a plain old m50.
      • Mr.SWISS
        • Nov 2005
        • 1251
        #1113
        yup
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • bimmerteck
          • 762
          #1114
          Looks like just a plain old m50TU.
          Fixed.
          • A_Whelan
            • Jul 2010
            • 691
            #1115
            I was looking at buying an M50 and the sellers told me that they had all the parts necessary for the OBDI conversion it needs but it's not installed.
            Need to do more research. Thanks for the posts.
            • Jand3rson
              • 37587
              #1116
              Ok, you guys that are using the E34 throttle cable, give me some insight here. Engine is in the car, as well as the E34 throttle cable. Everything seems fine, it's just that the overall length of the cable seems long. Does the extra length just kind of swoop down and out of the way? Obviously as long as the linkage is hooked up, it doesn't really matter how long it is, it's just not a straight shot from the firewall to the throttle linkage.
              • avery0829
                • Dec 2008
                • 793
                #1117
                I'm sure there is a proper way to put the slack, but honestly I just routed mine straight as possible and hidden.
                • Jand3rson
                  • 37587
                  #1118
                  Yeah, mine comes out the firewall and swoops down near the ABS hardlines, and then back up to the throttle linkage. I was just curious if other people have seen the same thing with the E34 cable.
                  • JGood
                    • Jan 2004
                    • 7959
                    #1119
                    Yes, same here. I'm using an e34 engine so I have a different linkage setup, and mine has to "swoop" up by the booster and stuff, back down to the linkage.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • e30rapidic
                      • 2167
                      #1120
                      funny. my e34 cable does not fit at the linkage
                      '87 325ic, powered by S50.
                      • giantkeeper
                        • Aug 2009
                        • 1416
                        #1121
                        I though of you when I read the post's above. I won't have my motor in until this weekend, but I'll update whether or not mine was too long or too short.
                        If I had to chose though, I prefer the the first :p
                        Always Always go for the reach around if there is an option
                        • BimmerTim
                          • Oct 2007
                          • 613
                          #1122
                          I have an S50, and I used an E34 throttle cable. It's tucked down by the booster and clutch master.
                          1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
                          2008 VW Rabbit
                          1991 Audi 200 20vtq Wagon
                          • dude8383
                            • Jan 2005
                            • 10387
                            #1123
                            BMWFans.info is 1000x better than RealOEM. MUCH better, clearer pictures, much easier to navigate, and just overall easier to use.
                            Actually, realoem has the pics too now. I prefer to use realoem b/c their servers seem to be faster.
                            http://www.realoem.com/bmw/partgrp.d...3&mospid=47484
                            Click "switch to images drill down"
                            • e30rapidic
                              • 2167
                              #1124
                              let me know what route you go!!! I may try to get to a local pick and pull later this week and scout about
                              • GT BMW E30
                                • Nov 2008
                                • 2491
                                #1125
                                question on S50 swap. I bought S50 engine/zf trans and guy gave me S52 throttle body/intake and S50 manifold. Can they be used and is there any extra performance or benefit?
