You spent about $400 on wiring adapter. Have you tried contacting the vendor?
The comprehensive DOHC engine swap thread.
This is a sticky topic.
pull the fuel relay and jumper it. See if power is coming to the relay. When you look at the socket, the jumper pins are at 6 and 9 o'clock if the slot for the odd ball pin is considered 12 o'clock.The fuel pump on my m50tu swap isn't turning on??!! The blue relay is getting power, I'm using a treehouse racing adaptor. The engine is getting spark. I don't get it.
I checked and there is no power going to the fuel pump, and no power going through the fuel pump fuse in the fuse box. Anybody got any ideas??
Also, I did s50 cams and a turner chip, but i don't think the chip would effect anything...Richard
silver or red label ECU? its possible you may have EWS...i had the same issue with mine, getting spark but no fuel :)The fuel pump on my m50tu swap isn't turning on??!! The blue relay is getting power, I'm using a treehouse racing adaptor. The engine is getting spark. I don't get it.
Also, I did s50 cams and a turner chip, but i don't think the chip would effect anything...IG: deniso_nsi Leave me feedback here
My point was that it doesn't matter weather I use a silver label or a red label. My car starts and runs and drives.
I didn't do any wiring for the EWS, so that is why it puzzles me about the silver labels and EWS.
1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
2008 VW Rabbit
1991 Audi 200 20vtq WagonComment
Alt radiator location, OEM SS exhaust mod, shaved doors, coolant bleed, oil cooler
A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
Alternative radiator placement, SS shroud, engine coolant bleed valve, oil cooler, shaved doors, side molding deleteDD -1991 318is panda
time travel vehicle - 1987 stupid light e30 2.9 m50/m52 all alum, rear H1E turboComment
Yeah It can run and drive until you chip it with a chip not designed for a silver label with EWS , in his case he has a turner chip. if its a silver label and hes running a red label turner chip it obviously will not work because the chips must be aligned to the ECU for units with EWS if i remember correctly...Comment
I got an S50 from an Automatic 95 M3...will the harness work with a manual trans or will I have to source a manual one
You can use the S50 harness. You can either leave the automatic harness or remove it.
I followed the link in the DOHC wiki site...Comment
