The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • BonnschE30
    • Jun 2008
    • 295
    #976
    so does the M50 water pump not use a gasket?
    • s1ick
      • Jan 2005
      • 97
      #977
      When changing the differential, which mounts you guys feel is most suitable for street use and where can I get them?
      -Thanks
        • 34839
        #978
        stock mount is fine. if you want an upgrade, go with an M-coupe diff cover.
        • JRKOUPE
          • Dec 2004
          • 3159
          #979
          -Thanks
          I ran a stock mount on a tracked car for yrs...its fine.
          • dkbmxer002
            • Nov 2007
            • 1389
            #980
            this might be a stupid question but is it hard to run a/c with this swap?
            • JdmEuroNorth
              • 222
              #981
              Originally posted by BimmerTim
              You have to use the 328is drive shaft. The rear flange to the diff on the M3 will have a 6-bolt CV style joint and the 328is has the 4-bolt u-joint style.
              Used an e36 driveshaft with a getrag 250. I got both with my engine.
              Fits perfectly.
              It seems everything people say won't work for my car ends up working.
              Now to run all of those cooling lines and wiring..... sigh..
              Function.
              Form.
              • dude8383
                • Jan 2005
                • 10387
                #982
                Fits perfectly.
                That should help.
                • JdmEuroNorth
                  • 222
                  #983
                  Thanks, that's quite helpful.
                  Although that setup is wrong, I don't see how it wouldn't work unless I want to drive my car in the winter, which I'm not.
                  Function.
                  Form.
                  • Jand3rson
                    • 37587
                    #984
                    As has been mentioned before, it's really hard to nail down specific information in this thread, so I'm just going to ask.
                    My current cluster is a custom-frankentstein build, but the important part is I'm using an '88 super-eta tach (6k) with the corresponding coding plug. In order to make it work with the new motor, I just need an i tach with the corresponding coding plug, correct? The fuel gauge will be the same, is the temperature gauge going to need to be changed?
                    • Wishno87
                      • 6025
                      #985
                      Correct me if im wrong but I think you need an 87i coding plug so you have the early gas tank with the "I" tach. I had an 89 cluster in my swap car and the gas gauge did not read correctly till I swapped the coding plug from my 87i cluster. Not certain but this has been my experience.
                      • Jand3rson
                        • 37587
                        #986
                        I do have an early gas gauge in the cluster now. I had to swap it in to replace the '88 gauge, because it read wrong.
                        So from what you're saying, I just need to get an '87 325i tach and coding plug. Temp gauge should be fine?
                        • Wishno87
                          • 6025
                          #987
                          Im still a noob to all of this cluster mixing around stuff but I think so. Your temp shouldn't pose any problems.
                          • Jand3rson
                            • 37587
                            #988
                            We shall find out!
                            • Gooch
                              • Dec 2006
                              • 1674
                              #989
                              On the issue of coding plugs, I'm assuming us M42 guys have to swap to a 6-cylinder (non-eta) coding plug?
                              '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                              '87 535i - Vacuum brake conversion [SOLD]
                              '93 525iT - 5-speed swap - 320k and counting
                              '09 328xi - 6-speed
                              • FredK
                                • 14759
                                #990
                                Yes, that is correct.
