The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • johnwoo
    • Oct 2007
    • 613
    #886
    Originally posted by e30s52
    413 red label will work or the silver but then you would have to get the ews delete
    hey thanks for the answer.
    so there is no restrictions on ecu. just make sure i pick up a vanos ecu 93-95? if so that would be great
    • e30s52
      • Oct 2007
      • 5235
      #887
      basicly. but if you get the silver label you have to get a chip to delete ews.
      www.gutenparts.com
      • johnwoo
        • Oct 2007
        • 613
        #888
        cool just get a red label 413. got it
        • e30_325es
          • 1249
          #889
          Can't you just clip a wire in the harness to delete ews?
          • Brew
            • 3060
            #890
            I've got a turner chip for a red-label 413 in my silver label 413 and it deleted EWS. I think they may just charge you extra for "EWS delete" and just slap a new label on the chip.
            '91 318is
            • SamE30e
              • Sep 2007
              • 4319
              #891
              Nope, I think EWS has to do with a chip in the key and such.
              1985 325e 2.8 Turbo VEMS
              • strad
                • Jan 2007
                • 241
                #892
                Okay: got a 91 318i M42 here that I've installed a 13 button OBC in. Let's say I get an M50 NV to install in this car. What coding plug or other mods would I need in order to make the obc work properly with an M50? Or is it even possible?
                I know it's a small thing, but I've got the large things pretty much figured out already.
                The current fleet:
                1992 325ic: 148k-171k miles
                1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                • hoveringuy
                  • Dec 2005
                  • 2752
                  #893
                  I have gotten two Silver label ECU's out of '94 cars and they didn't have EWS. Starting in model year '95 they did.
                  • Bmwmotorm52
                    • 145
                    #894
                    I readed that I can use stick (e30 325is) brake booster and move 1/4in to the rhght to get get the clearance i need. How?
                    sigpic:):)
                    • omar85
                      • 331
                      #895
                      when swapping in an s52 besides the intake mani and wiring harness, what sensors needed from an obdI M50?
                      • e30s52
                        • Oct 2007
                        • 5235
                        #896
                        You need all the sensors from an obd1 m50/s50 also the e30 temp sensor.
                        www.gutenparts.com
                        • myinfernalbmw
                          • May 2007
                          • 1736
                          #897
                          I am looking to put together an adapter similar to the AKG and Treehouse setup. Does anyone know the part numbers for the two connectors I need?
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            #898
                            C101 and X20?
                            They are made by AMP. I will try and get them for you tonight.
                            Past Car : E30 S50 6 Speed 5 Lug 3.73
                            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                            ___________________________________________
                            BNB Designs
                            Engine Swaps, Fabrication, Innovation, General Repair
                            Richmond CA
                            Julian 848-248-8029
                            • myinfernalbmw
                              • May 2007
                              • 1736
                              #899
                              Originally posted by jrdeamicis
                              C101 and X20?
                              TIA sir. I don't have a problem ordering them through the dealership, I have a wholesale account with them. I just don't exactly know which connectors I need to use and my parts specialist wasn't 100% either so I thought I would ask the resident experts.
                              • MR E30 325is
                                • Dec 2008
                                • 3300
                                #900
                                Alright, I have read this entire thread twice over the past couple weeks.
                                First question.
                                Porsche 944 brake booster. One post says that I just need to cut the rod and it will be good enough. Another post says it needs to be cut and rethreaded.
                                I want to do the 944 BB due to the cost, and I dont have access to all sorts of welding tools and such.
                                TIA
                                My previous build (currently E30-less)
                                http://www.r3vlimited.com/board/showthread.php?t=170390
                                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
