The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • 2mAn
    Señior Mod
    • 21049
    #1276
    can someone answer the question above about the temp sensors?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • kevdeno
      • Jul 2006
      • 45
      #1277
      Coolant Temp Sensors:
      On your E36, one sensor is for DME and the other is for gauge cluster. You have to replace the sensor which feeds signal to the E30 gauge cluster so it will read correctly. The E36 one reads a vastly different resistance for a given temp.
      1. E36 DME, E36 coolant temp sensor.
      2. E30 gauge cluster, E30 coolant temp sensor. Just thread it into the spot where the old E36 coolant temp sensor for gauge cluster was. See your wiring documentation to make sense of which wires do what, but it should be in the harness already and you don't have to do anything.
      • 2mAn
        Señior Mod
        • 21049
        #1278
        So I need one more coolant temp sensor (E36/E34) to go to the DME and I can use the one I currently have (M20, blue with 2 pins) and just have to wire that to go to the cluster.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • Roysneon
          • 4505
          #1279
          Leave the one for the DME alone and re use your old m20 one for the cluster.
          Originally posted by mbonanni
          I am a pursit now.
          • 2mAn
            Señior Mod
            • 21049
            #1280
            mine doesnt have any sensors, so Ill need to buy the E36/ E34 one
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • kevvve
              • Apr 2012
              • 670
              #1281
              I was going over what I've done so far and this bracket looks bent to me. Can anyone chime in? Anyone have a part number?
              BUILDTHREAD
              WTB LIST
              • agent
                Vice Grand Pubaa
                • 7960
                #1282
                I believe that has to come off for (some?) E34 pans to fit.
                Originally posted by kronus
                • jclar
                  • 265
                  #1283
                  Seconded, iirc the e34 pan won't fit with that on anyways.
                  '86 325es M50
                  • 36brua
                    • 689
                    #1284
                    ^^ true . if you remove the bracket vs. cutting off the vertical leg , you need 2 new main cap bolts. they are TTY
                    My CA legal M60 swap
                    The happening in our garage
                    • kevvve
                      • Apr 2012
                      • 670
                      #1285
                      Thanks guys I appreciate the help.
                      BUILDTHREAD
                      WTB LIST
                      • pmat
                        • Nov 2012
                        • 174
                        #1286
                        Dunno if its been mentioned, but a coding plug from a e28 535i works. the housing dosent fit in the e30 cluster tho, gotta take the chip out of the e28 plug.
                        318is, m50tu g240 s3.46
                        • 2mAn
                          Señior Mod
                          • 21049
                          #1287
                          where do the intake temp sensors connect? according to the diagrams Ive found, there is two? does one plug into the head next to the coolant temp sensor?? its roughly the same location
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • Steven
                            • Dec 2012
                            • 2305
                            #1288
                            Quick question, how many pins should I need to repin the c101?
                            Feedback!
                            Custom Cup Holder Consoles!
                            Calypso Story--S50/Shaved and Tucked Bay
                            • bimmerteck
                              • 762
                              #1289
                              Depends on if you're keeping all chassis functionality(I've removed some circuits on cars being prepped for track use since the OE idiot lights are not useful if you have no stock cluster.) and whether you're adding any circuits for ancillary gauges and such. IIRC you can do it with as few as 7 pins but all my customers/friends end up closer to 22 male and 3 female. I add an x20 to the e30 so I could have up to 25 male pins. If you reuse the c101 you should need no more than 20 male pins. Though you need to figure out how many of them need to be large vs small. Post below is from my build thread showing how I generally rewire them including PNs for the factory pins and the pin removal tool. ;)
                              • Steven
                                • Dec 2012
                                • 2305
                                #1290
                                http://www.r3vlimited.com/board/show...1&postcount=55
                                Oh I saw your thread, I was really wondering hw many large and small pins I should order.... I should've been more specific. I'm not adding or taking out anything.
                                Feedback!
