The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • golde30
    • 11464
    #1291
    IG: @Baye30
    • Steven
      • Dec 2012
      • 2305
      #1292
      That's perfect! Thanks
      Feedback!
      Custom Cup Holder Consoles!
      Calypso Story--S50/Shaved and Tucked Bay
      • bimmerteck
        • 762
        #1293
        Originally posted by Steven
        Oh I saw your thread, I was really wondering hw many large and small pins I should order.... I should've been more specific. I'm not adding or taking out anything.
        The number and size required varies slightly by chassis, year, and options. On the '88 M3 I wired this evening I used 12x small(191), 2x medium(193), and 2x large(195), I don't typically count but I was already at it. I know the 318 I wired last week took 1 more medium and at least 1 less small but it was a later chassis so it had the ABS pin in the 101 but no oil temp b/c it wasn't an "M". The easiest way to know what you will need for sure is to flip your chassis's c101 over, pull back the boot and count.
        In the picture below the left most(BR/GN) uses a 191, middle(GN) uses a 193, and the right most (VI/RD) is a 195.
        • Steven
          • Dec 2012
          • 2305
          #1294
          This is why I love this forum. So informative. Thank you
          Feedback!
          • Steven
            • Dec 2012
            • 2305
            #1295
            As far as condor motor mounts go, which arms will I need?
            Feedback!
            • 36brua
              • 689
              #1296
              Same as other mounts E36
              http://www.realoem.com/bmw/partgrp.d...id=47498&hg=11
              My CA legal M60 swap
              The happening in our garage
              • 2mAn
                SeƱior Mod
                • 20946
                #1297
                Just wanted to double check, but 24v with G260 MUST have 323i Throwout bearing, correct?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • 2mAn
                  SeƱior Mod
                  • 20946
                  #1298
                  Problem : NON-ABS car using the iX booster and master. Solution:???? So far Im thinking that I need to "T" the front lines into one, and the other one to be used for the rear
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • Rdreas
                    • Aug 2013
                    • 164
                    #1299
                    This is what im planning on doing i ordered a t and fittings from fedhillusa.com
                    • 2mAn
                      SeƱior Mod
                      • 20946
                      #1300
                      The "T" I used was a factory piece that the E30 has in the back, underneath the car. This eliminates having a different pitch/ thread/ diameter as factory. Hope yours works out
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Cerruti
                        • Oct 2013
                        • 1
                        #1301
                        Hi Guys,
                        I'm currently working on a built m50b30 swap. My car was a '89 325i e30. The engine is very close to the firewall and I don't know how should I connect the heater hoses. I'm using e28 535i mounts with washers on the driver's side.
                        Another problem is that the engine is not sitting perfectly straigt in the engine bay. The front is a little bit close to the passanger side while the back is close to the driver's side and the whole engine almost hits the firewall. Unfortunately it is not visible on the picture.
                        How can I solve these issues? Any idea would be appreciated!
                        • kevvve
                          • Apr 2012
                          • 670
                          #1302
                          Anyone know where I can find the harness bracket that connects to the block and chills under the intake manifold???????????!!!!!
                          Thanks!!!
                          BUILDTHREAD
                          WTB LIST
                          • Steven
                            • Dec 2012
                            • 2305
                            #1303
                            Do I have to run an oil cooler for a 24v swap? I know my m42 didn't have one...
                            Feedback!
                            • golde30
                              • 11464
                              #1304
                              No, oil capacity is ~6QT on these engines, you are good without it.
                              IG: @Baye30
                              • 2mAn
                                SeƱior Mod
                                • 20946
                                #1305
                                I cant find the part # for the 2002 brake resevoir. one of the last things I need. I found the blue cloth hose 21521163714 but Im sure I need two fittings in addition to the resevoir itself.
                                edit: thanks Jeff!
                                Here are the part #s to get the 2002 remote resevoir setup
                                (1)- 21 52 1 163 714 = Blue Cloth Hose
                                (1)- 34 32 1 112 388 = 2002 Brake Fluid Reservoir
                                (2)- 34 32 1 102 282 = Angula Pipe
                                (2)- 34 31 1 121 911 = Rubber grommets for the reservoir
                                second edit:
                                you will also need two new grommets for the reservoir also. that werent mentioned anywhere else I looked
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
