[HOW TO] e46m3 6-speed your e30
  • chuck90m3
    • 568
    #46
    ZF transmission, totally different setup then the GETRAG.
    "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
    Friedrich Nietzsche
    • matt
      • 3732
      #47
      Originally posted by chuck90m3
      I was thinking of doing the same thing. Use a E36 clutch and LTW flywheel but then just replace the friction disc with one from the E46 M3 6spd. Can anyone think of a reason why this wont work? The disc is the same size and thickness. So we should be ale to use this clutch/flywheel combination and also eliminate the E46 self adjusting clutch setup as well.
      The pilot bearing for the e46 trans is mounted in the flywheel, I believe. There is some sort of adapter for that that lets you use the e36 FW with the e46 trans.
      • chuck90m3
        • 568
        #48
        not on the GETRAG just the ZF
        Friedrich Nietzsche
        • madjurgen
          • May 2005
          • 1203
          #49
          Ya I know, thats why I said 'zhp'. It was asked if the ZF could be used instead of the GETRAG so I posted a link showing it works with mostly stock parts.
          As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
          You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
          • MDryVur
            • 395
            #50
            bump... to the top by the stickys..
            • m3_eater
              • 413
              #51
              Just adding a little info for those considering a 6-speed swap. Here's the speed/RPM calculations for an E46 M3 6MT (S6S 420G) with my tire size and differential. I can post other combinations if anyone needs, including substituting gear ratios for the ZF 6-speed. LMK.
              E30 24V 6MT SOLD :( - look for it in sunny Miami :)
              • rThor432
                • Feb 2007
                • 3907
                #52
                ^^ I love that gearing..
                • bmike666
                  • Jan 2008
                  • 13
                  #53
                  why use a e36 slave cylinder
                  Originally posted by beirbrennere30
                  i get asked pretty frequently how i fit the getrag s6s-420g transmission from the e46 m3 into my e30. So instead of answering the question a few times a week i thought i would just do a write up of the parts necessary and some tips and notes.
                  Parts:
                  E46 m3 getrag s6s-420g transmission
                  e46 m3 flywheel
                  e46 m3 clutch
                  e36 325i clutch slave cylinder(there may be a better option out there but i know this works, the pedal is kinda light for my taste)
                  custom trans x-member
                  automatic e36 m3 with e30 csb driveshaft
                  e46 m3 guibo
                  e36 engine to trans mounting hardware(e46 stuff is too long)
                  e46 m3 driveshaft to trans hardware (12mm bolts)
                  e36 m3evo shifter assembly(details below)
                  e30 late model rear shifter mount
                  shift knob with 6-speed shift pattern ;)
                  install highlights:
                  The e30 reverse light switch threads into the e46 trans no problem and functions
                  you need a lower rear end gear ratio. I run a 3.91 and its very streetable. For a daily driver the 3.73 would probably be perfect.
                  For the shifter you need the e36 m3evo 6-speed parts:
                  thats everything in the above pic except 12,13,14,15. You need 1-11! This will slide into the late modle e30 rear shifter support. For early e30s(pre '86) you need to convert to the later style mount.
                  For a drive shaft you need one of custom length made. ( or apparently you can use an e36 m3 automatic driveshaft with an e30 center support bearing swapped in ) bimmerworld made mine and make a very quality unit. They will send you a sheet to fill out with critical measurements like the one below.
                  for me the measurements were the following:
                  1. 21.5"
                  2. 54.375"
                  3. 1.375"
                  4. Stock e30 non-m length
                  5. E46 m3 flex disk
                  6. 12mm bolt hole
                  these may change depending on your particular set-up. Make sure you confirm these measurements on your car before you order. If it doesn't fit its your fault!!!
                  As for the custom x-member your on your own. You can use the stock e30 x-member and weld on extensions so that it reaches the front and rear sliders.
                  Thats it!
                  Technical notes:
                  Gear ratios:
                  1st 4.23
                  2nd 2.53
                  3rd 1.67
                  4th 1.23
                  5th 1
                  6th 0.83
                  the internals of this transmission are the same used in the 6-speed mkiv supra. So its basically indestructible.
                  This trans is the upgraded version of the e36 6-speed. The syncro problems of the e36 were fixed to solve the miss-shift problems and early wear.
                  will a e46 m3 slave work
                  • BMWtech@mac
                    • 140
                    #54
                    ^^ I also would like to know?
                    08' BMW M5
                    07' BMW Z4M Coupe - SOLD
                    95' BMW M3
                    87' BMW 535is
                    Bring Bangle Back...
                    • BeirBrennerE30
                      • 2740
                      #55
                      im sure you could hook it up but i have no idea what your clutch pedal would feel like. Try it
                      e30sport.net
                      '06 M3 Competition - 6-speed
                      '97 Range Rover Vitesse
                      • e30polak
                        • 6136
                        #56
                        I want to do this tranny with a 3.46, get into powerband a little quicker! :D
                        INSTAGRAM: @UNDR8D_EMPIRE
                        • GGray
                          • Dec 2008
                          • 26
                          #57
                          Nice
                          Thats perfect with a 3.25. You can hit 60mph in second gear. for a track being able to hit 124/125 is great most of the tracks I go to at the end of the straight your pulling 120ish. Not having to shift up a gear and back down two is perfect...
                          I just bought a 1990 325 with an S50 in it:up:
                          Gary Gray
                          88 M3 M5x turbo track/race car
                          89 M3 alpine/blk
                          91 M tech vert
                          91 GTi 16V
                          01 325it aka: Wagonator...
                          If you can take it apart you can make it faster....
                          • BMWtech@mac
                            • 140
                            #58
                            Does anyone know for sure, if the e46 M3 SMG trans is the same as the regular 6 speed in a e46 M3. Would you need any other parts to make it work? Gear ratios the same? If you take off all the SMG stuff, can you use this trans in this swap? Also, is the 6th gear a considered a overdrive gear? The reason I ask is I'm already running a 3.73 rear gear and I would like to be able to drive on the highway at something less than 4500 rpms like I'm at now... the reason I don't drive my car on the highway, haha.
                            Christian
                            08' BMW M5
                            95' BMW M3
                            87' BMW 535is
                            • chuck90m3
                              • 568
                              #59
                              They are not the same. I thought so as well but after buying one found out that the SMG transmissions come without the necessary parts to center the shifter in neutral and provide the shifter with the dedent for reverse. We have sourced out the parts to make them work but you need to drill and install a few springs and guides so the transmission will work properly. As for the gear ratios they are the same.
                              Friedrich Nietzsche
                              • BMWtech@mac
                                • 140
                                #60
                                ^^^ Thanks for the info. I always seem to come across the SMG's for sale at good prices so it was just a thought.
                                08' BMW M5
                                95' BMW M3
                                87' BMW 535is
