[HOW TO] e46m3 6-speed your e30
    It can be done, we did three this month for our project cars
    "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
    Friedrich Nietzsche
      i have a spare smg tranny
      wondering if you can get mine to work normal and how much? thanks
        I can it is around $450 with parts and you would need to cover shipping
        Friedrich Nietzsche
          how about the 420 out of the e34 will it work?
          24v swapped
            wrong bellhousing you need a 6SMT from a 6 cylinder car
            Friedrich Nietzsche
              damn
              24v swapped
                Can't wait to use this write up next year after deployment.
                  If you use the e46 330 Tranny, you need a flywheel from a Z4, X3, X5, 330 from 3/03 and some other cars. You can make an adapter to use a S50 flywheel but I did not use that in my swap.
                  Also you need to use the Shifter carrier from the e30 since the 330 tranny uses dual mounting points instead of single like the e46 m3. It must also be shortened.
                  Just some fft.
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                    What's a good price for the proper tranny?
                      The prices are all over, I got my 6 speed for a G. But that was a SLAMMIN good deal.
                      Anywhere from 1k up to 2k.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                        www.car-parts.com
                        BNB Designs
                        Richmond CA
                        Julian 848-248-8029
                          FYI, I have read that you can use an automatic e36 M3 DS for this and have it bolt up. I purchased one just to see and it is way to short. Either I was sold the wrong drive shaft or this is not possible.
                            You can use that DS with the ZF transmission, they are talking about the getrag here.
                            -Cam
                            Cam .W '91 325is
                            Spaz's 1991 Alpine White???? S52 Build Thread...
                              Anyone making the cross member for this?
                                ^ wondering the same thing, i still need one.
