Another S52 swap... but this time with a newb!
LOl. Sheesh. Its going to be loud and I gotta tape up the hfm to the stupid undersized wrong buying bimmerworld throttle body boot lol. Oh well, lets see if it starts. =) cross your fingers!!!
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
=( cranks but doesn't start! AHHHHHHH! Checked for spark and I got spark. I didn't reverse the fuel lines as I double/triple checked before I hooked them up. My fuel pump isn't priming up before I start it so I'm double checking my wiring harness right now.
What things would make a car not start again? I've heard that a bad temp sensor (for ecu) would cause it not to start. Bad cps? Iono. I'm so close! It sounds like it wants to start... but its not! :x :hitler:
Mine turned out was a ews ecu, but other things are crank sensor, which looks like the ICV I believe, my buddy got those reversed last week. Crack the fuel lines, mine wasn't wanting to go and I was positive the lines were correct, sure enough, popped the line and it had fuel, so I reversed and fired up. Friend did the same on his. So that's where I would start, even if your positive...
edit: oh yeah, tps sensor as wellComment
So try reversing the fuel lines? I'm running a 413 silver label with ews delete. I've read that people say that pin 7 of x20 immobilizes the starting. But I removed pin 7 from the x20 long time ago to avoid that problem... How do I check if the dme is getting power?
mine shows on dme plug should be pin 26 is hot all the time, and then pin 56 is start pin.Comment
Fuck me... I was stupid and reversed the fuel lines... wow... I failed to notice that the lines twist before they come up to the engine bay thinking the adverse of what they really were from researching on realoem.com. Ha. Shit started up like nothing! OMFG! I'm coughing from the fumes because I have no headers on! HAHAHA. God damn it... I'm so happy. No problems but the freaking lines... how stupid. Ownedizzled.
Nice job! Are you using OBD1 or OBD2 coils with the obd2 cover?
Fuel/temp/tach working? Not asking about speedo yet as you probably haven't driven it yet with no headers lolMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I'm using a obd1 valve cover with new (1 year old) obd1 coils. Haven't even bothered to look at my gauges as I started the car outside of it trying to hear for abnormal sounds before I destroyed it... but non to my avail!
Things I need to get this on the road... obd2 headers welded/obd1 midpipes (So I could atleast drive to the exhaust shop) and throttle cable from a e34 m50 or any e36 325i.
Man, I never thought I'd see this day... haha. Woot!
