Another S52 swap... but this time with a newb!
  • jakeb
    • 1909
    #121
    yes you can get ebay headers in and out with the engine in the car. It takes a little wiggling but its not that bad. I had ebay header and pulled them out and went obdII headers. If that is what you hve now, stick with those. The ebay headers are pretty raspy.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • Mohammed_A
      • 344
      #122
      Originally posted by devonjordan
      yes
      tell me more please
      • 318isbmw
        • Nov 2005
        • 2841
        #123
        The rest of the exhaust has a lot to do with that also though.
        Has anyone tried putting the m5 and 535 motor mounts next to eachother, I wonder how much taller the 535 is...
        • jahnaboi
          • Oct 2006
          • 1742
          #124
          From what I heard they are relatively the same diameter/tolerance levels. The m5 came with a 3.6 litre which weighed in probably only 20-50 lbs heavier (or lighter) than the m30b35 in the 535i/is... "so I think". Lol.
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • jahnaboi
            • Oct 2006
            • 1742
            #125
            Note to self: Never put the fuel injector rails + fuel injector harness before bolting down the intake manifold... because you'll never get the last screw for the intake manifold against the firewall.... God its so tight in there!!!
            • jahnaboi
              • Oct 2006
              • 1742
              #126
              P.S. - shimming the motor IS A MUST to clear the intake manifold using a ix/7 series booster.
              • flyboyx
                • 8371
                #127
                what do you mean by "shimming"?
                Gigitty Gigitty!!!!
                • 318isbmw
                  • Nov 2005
                  • 2841
                  #128
                  Get a 1/4 drive and you should be all good for getting that in there. put some paper between the nut and the ratchet so it stays in there since you can't get your hand in there and you should be golden.
                  Yeah, I know what motors came in what. I'm just wondering cuz I know mine's higher than 2 inches and that's w/ the Ireland stage 3's on it w/ 535 mounts.
                  As for shimming, its just putting a washer or piece of metal underneath the motor mount to tweak the placement up higher on that side.
                  • jahnaboi
                    • Oct 2006
                    • 1742
                    #129
                    Too bad I don't have my 1/4 ratchet/sockets/extensions... My dad has most of my tools... LOL. Its fine. I'll find a way... I think. LOL.
                    • Mohammed_A
                      • 344
                      #130
                      This might be a silly question but does the CHECK lights still work properly after the swap as well as the cluster warning lights???
                      • devonjordan
                        • Jul 2006
                        • 2386
                        #131
                        Originally posted by Mohammed_A
                        tell me more please
                        Someone here makes skidplates, dont remember who though.
                        Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
                        Help a brother out, buy your detailing products here...
                          • 37829
                          #132
                          As long as it's done correctly, yes.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • jahnaboi
                            • Oct 2006
                            • 1742
                            #133
                            12/7/08
                            Here's the update!
                            A picture of my ghetto jimmy rigged e30 temp sensor for my cluster. I live in socal so I deleted my coolant lines to my throttle body as temperatures here in So Cal don't really get that cold (818).
                            Picture of my 24lb Bosch injectors.
                            And here's where I am so far... just really small stuff to connect like throttle body boot, hfm, and I need obd1 mid pipes. Anyone got any?
                            -Jasper
                            • 318isbmw
                              • Nov 2005
                              • 2841
                              #134
                              Looking good. I'm guessing that the coolant port is a different fitting than the Temp gauge... Good temporary fix, looks like it'll do the job nicely. I'm guessin you figured out the screw, that's a bitch w/o a 1/4 set.
                              • jahnaboi
                                • Oct 2006
                                • 1742
                                #135
                                Yea, what I did was disconnected the injector harness from the injectors and set that aside. Then unbolted the mounting bolts for the fuel rail and slid it upward. Amazingly enough it was so much room that I got the bolt with ease with my 3/8, foot long swivel extension. I'm soooo close. I could smell the fumes. LOL
