Another S52 swap... but this time with a newb!
  • jahnaboi
    • Oct 2006
    • 1742
    #301
    Originally posted by e30polak
    You may have clearance issues with the front mid pipe, so be ready to space the motor up on the right side. You will probably have to shave the fins off the intake manifold if you're using the 320 booster.
    Hopefully I don't have any clearance issues. I shouldn't have to to space anything because these were made to fit a stock e36 with stock midpipes. Plus, I'm using a ix/735/750 booster and the fins already have been shaved. =P We'll see how this works out.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • e30polak
      • 6136
      #302
      Those are knock off headers, i can almost guarantee that there will be fitment issues. :p
      INSTAGRAM: @UNDR8D_EMPIRE
      • e30s52
        • Oct 2007
        • 5235
        #303
        I had fitment issues with my SS knock offs. It really sucked sence my whole exaughst system was done at that point too.
        www.gutenparts.com
        • jahnaboi
          • Oct 2006
          • 1742
          #304
          Lol. I really hope not because the guy I talked to said that it will bolt up just fine. LOL. We'll see. Haven't pulled the trigger yet, since I'm still doing my rear sub-frame freshen up. Man, so much shit to take out before you actually get the sub-frame out... wack. Lol.
          • jahnaboi
            • Oct 2006
            • 1742
            #305
            Could you post a picture of the ones you got ?
            • norcalE30
              • Dec 2008
              • 932
              #306
              hey nice job, ive been wanting to do this since i got my e30.... can you make me a thorough list of all the mods and parts you needed to get this done? i really want to do this
              it looks great, well done
              Originally posted by kronus
              pff, all of you are slow as hell anyway. Eta > all
              • MikeK
                • Jan 2005
                • 2771
                #307
                jasper! where the fawk are my vidoes ehhh??? :)
                Toyota Pickup
                • e30s52
                  • Oct 2007
                  • 5235
                  #308
                  Here you go. Sorry they are so dark. Thier is no light in my garage at all.
                  -alex
                  www.gutenparts.com
                  • jahnaboi
                    • Oct 2006
                    • 1742
                    #309
                    I see. I would see why they had fitment issues. The ones I'm getting are short equal lengths. Hopefully I don't run into any problems.
                    I put my IE race subframe bushings/IE street urethane tabs/ss braided lines/2.93lsd diff in last night... Man the car feels better and is more happier freeway wise!
                      • 37829
                      #310
                      Very nice! Those are kind of long gears though, do you like it?
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • DaveSmed
                        • Apr 2007
                        • 1407
                        #311
                        Would a blue top sensor (ecu temp sensor) work for the e30 gauge? I know the answer is no.... but how accurate would it be? Would the cluster even read it?
                        I dont know. I didnt try because everyone says it wont.
                        People say that the black sensors don't work...
                        You know, (to dig up an old problem..) I am actually wondering if the black sensor will work. The reason it will give no reading with just the Brown/Violet wire @ pin 12 of -X20 is because the instrument cluster also provides the ground reference for the sensor via pin 11 of -X20.
                        If you were to ground the Brown/Green wire on pin 11, and connect pin 12 to the cluster, you would get some sort of signal. Very possible that it could be the same resistance range.
                        -Dave
                        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                        Need some help figuring out the ETM?
                        • Mohammed_A
                          • 344
                          #312
                          Originally posted by rThor432
                          I think the brown single pole sensor is the one for the guage cluster? I believe that is the one you need to use.
                          so u have to use the brown sender from the e30 but is there a plug on the s50 harness that fits the sender or must a plug be modified?
                          • jahnaboi
                            • Oct 2006
                            • 1742
                            #313
                            Not long at all. Not much longer than a getrag 260 with a 3.73. At 80 with my getrag 260/3.73lsd I was at 3500 rpm but with my ZF/2.93lsd I'm at 3100 at 80mph. Still lots of torque and still lose traction on first and second when throwing it into gear (Almost losing traction fully on second).
                            Do I like it? Hell yea. Love it. Couldn't be happier. But I do have a noise coming from the rear end... don't know if its the tires transferring noise from the ground to my cabin because of the stiff ass bushings or my 2.93lsd is humming. I checked the diff before slapping it on and cracked it open. No shavings, and was a factory rebuilt. So it felt real good. Just don't think its it. But could always be a possibility.
                            Dude, are you going to try grounding pin 11 of the x20? If it works, let me know.
                            • jahnaboi
                              • Oct 2006
                              • 1742
                              #314
                              Anyone run these headers?
                              • e30polak
                                • 6136
                                #315
                                Just buy the ebay headers and call it a day! :hitler:
                                Otherwise look into KK headers or TMS shorties if you want to be a baller! ;)
