KwikBrik: Back from the dead after 13 years
  • 128keaton
    • Apr 2020
    • 115
    #31
    [double post removed]
    • 128keaton
      • Apr 2020
      • 115
      #32
      Got the wheels back from Discount. Looks really good!! Also mounted the rear spoiler, holes are ugly as hell, but even measuring twice/thrice over it just wouldn’t line up according to the diagram. Ugh whatever. Sent from my iPhone using Tapatalk
      • 128keaton
        • Apr 2020
        • 115
        #33
        Slowly putting the trim back on the car, the DIY shadowline I think is turning out great. Really pops with the white on the car!
        553473E2-792D-472E-BC02-F0D264C839EC_1_105_c by keaton.burleson, on Flickr
        DF94B7C4-D424-49E7-866E-D7125B19C4C6_1_105_c by keaton.burleson, on Flickr
        822D35F1-0277-4B1C-80A6-C0406DBA392F_1_105_c by keaton.burleson, on Flickr
        71A751EE-7D58-4F31-8D1C-9C7EF3D96FC4_1_105_c by keaton.burleson, on Flickr
        The euro grilles and DEPO lights look absolutely fantastic:
        23370273-5938-46B7-8780-36C38AD2D45C_1_105_c by keaton.burleson, on Flickr
        More to come, as always
        • e30davie
          • Apr 2016
          • 1788
          #34
          very nicely done. I do love a home paint job.
          What sort of paint did you use? thinners based or 2 pack?
          • 128keaton
            • Apr 2020
            • 115
            #35
            I haven't specifically heard those terms before, but it was base coat/clear coat (2 stage) with a 2k acrylic clear coat.
            • 128keaton
              • Apr 2020
              • 115
              #36
              I’ve spent this past week finishing the seats and doing little odds and ends. Most importantly though, I mounted the IS air dam Turned out really well in my honest opinion. I spent time aligning the trunk lid some more after replacing the gas shock. Almost perfect, the right side is great, but the left has the typical issue where it’s open a bit more at the rear due to the shock. I then replaced the seal plugs in the trunk which were drilled/knocked out when I pressure washed the trunk area. These are pretty cheap from BMW and I highly recommend replacing them as needed when doing usual rust prevention or fixing. One of mine had the wax fail so it wasn’t sealing as well as it should’ve been. Just pop them in the hole and run a heat gun on them until the wax melts a bit. Good as new. I’ve replaced the grommets/clips and the panels on this lid, but the leather has shrunk causing fitment issues. Hoping these clamps stretch it out, but I might have to cut some of it under the black labels to release some tension. Also finally finished recovering the rear seat back. All the seats are done minus the back panels of the front seats. Still figuring out suspension. Sent from my iPhone using Tapatalk
              • 128keaton
                • Apr 2020
                • 115
                #37
                Slowly but surely, moving forward. Started painting the door cards. I painted my rear door card with special vinyl/plastic dye/paint and it has held up surprisingly well and matches the natural beige color perfectly. So much so, I had trouble telling where I had already sprayed on the passenger side door card:
                IMG_2589 by keaton.burleson, on Flickr
                And dry!
                IMG_2590 by keaton.burleson, on Flickr
                I painted after spending 25 minutes scrubbing and cleaning every nook and cranny, then wiping down with a grease remover for paint. Turned out really great, much better than the faded/sun damaged plastic and vinyl.
                Also got my new turn signal lenses delivered, so satisfying!
                2E223918-76D9-45A2-B207-CF0B38388303_1_105_c by keaton.burleson, on Flickr
                I ordered a ton of stuff for moving forward. Namely, stuff to hopefully fix the rear diff leak I have. I'm hoping its just the rear cover seal or the CV axle seals/o-rings and not the input shaft seal. I can manage replacing that, but I'd prefer not to touch the crush sleeve or the preload at all, since thats all seemingly fine. Now, for CVs. Not sure on this yet, I think mine are fine, but at roughly $300/side, they're pricey.
                Since I added heating elements to my seats, I needed seat heater switches. The E30 switches on ebay looked terrible, considering folks wanted upwards for $40 for a dirty switch with cracked plastic and worn lettering. I was able to snag a pair of E36 switches with the pigtails for $45. Seeing as how I need to add holes to my console, this works out great, since I'm not sure if the E30/E36 switches are of the same size.
                Waiting on another shipment from FCP to finish up the trunk trim and a few other odds and ends with the trunk. Also ordered the seal for the rear deck lid. I think next I'm gonna try and tackle replacing the soft top. That or, fit my dash cover so I can get the glass put in since I do have a new seal and lock ring.
                • 128keaton
                  • Apr 2020
                  • 115
                  #38
                  Okay, a lot has happened since I last posted.
                  Soft top is on, waiting on more seals to arrive, but its close! Its near brand new at this point, repainted the soft top frame and cleaned out everything in the storage partition. Replaced the tension straps as well as the associated rivets and screws. Today, I finally got around to replacing the shocks and their sleeves. Thing opens and shuts like brand new at this point, but the rear lid plastic always catches on the soft top. Annoying, might have to adjust the lid a bit. Speaking of, the cable that connects the trunk to the soft top lid is broken and NLA from BMW. Anyone have a fix or part that works in its place?
                  IMG_2701 by keaton.burleson, on Flickr
                  IMG_2702 by keaton.burleson, on Flickr
                  I retrofitted E36 window switches as well as the E36 heated seat switches in my interior. I got the last E36 heated seat retrofit harness from what I can tell, and I added it to the E30 harness in a non-destructive way. I tapped into the external fuse box present in the engine bay for power supply and then adding the 15A fuse (noted from the E36 EWD). From there, it was just routing the harness through the interior
                  IMG_3166 by keaton.burleson, on Flickr
                  IMG_3167 by keaton.burleson, on Flickr
                  IMG_3168 by keaton.burleson, on Flickr
                  The wiring under the dash is so spaghetti, is that an E30 thing or just a my E30 thing?
                  The center console really looked nice after adding the switches and painting it all:
                  IMG_3123 by keaton.burleson, on Flickr
                  At long last, the car has a full interior again!
                  IMG_3179 by keaton.burleson, on Flickr
                  The M52 ran hot in the previous shell too and this summer has been absolutely brutal. Was seeing temps on OBD-II that were nearing 230F, not good. I opted for a full cooling system overhaul of sorts, replacing the presumably original M20 radiator with a new M20 radiator (OE style with plastic tanks) with a lifetime warranty. I replaced the coolant inlet with the E39 inlet, also allowing me to run a shorter hose. The E39 inlet was cheap and aluminum, but had the all important bleed screw. I hate bleeding the coolant system on the M52 honestly, but the bleed screw made it really easy. I also dropped in a 72*C thermostat, which I think is honestly perfect. The three center marks of the E30 temp gauge have a spread of 20 degrees roughly, the first mark is 200F, second is 210F, third is 220F. This is just what I measured with OBD-II while noting the position of the needle. Unless I'm really running it hard, it stays mostly between the 200-210F range which is honestly perfect. The fan kicks on from the radiator switch right after middle mark too, I don't know if thats due to the radiator replacement or the fact that coolant is circulated through the radiator sooner, allowing for it to heat up faster. Either way, it really works together well now. I was worried I would have to buy a diesel fan and replace my WP to have an engine driven fan, but I really enjoyed the lack of a mechanical fan, makes working on the engine while its running a lot safer and plus I'm not lugging any extra mass where I don't need to. If it doesn't get warm enough in the winter, I'll have to figure something else out then, but I don't think that'll be much of a problem considering how the heater would just about drive you out of the car in the winter.
                  Picture of the E39 coolant inlet (p/n 11531740478):
                  IMG_3169 by keaton.burleson, on Flickr
                  Everything all installed on the car:
                  IMG_3174 by keaton.burleson, on Flickr
                  Also had my dad work on cleaning up the glovebox and getting the OBD-II port mounted:
                  IMG_3178 by keaton.burleson, on Flickr
                  Me and my other friend who collects German junk (E30s, E28s, etc) have a habit of asking "does your glovebox work" before opening it on either of our respective cars. Still have to slam mine shut but its nice at least.
                  Finally got my fast blinker solved, was just simply using the wrong bulb. My driver's side running light still doesn't work, need to figure that out before too long.
                  I did order the H&R sport spring + Bilstein combo from Bimmerworld, as well as new brake stuff for all four corners, new front wheel hubs, and spring pads. Already have new tophats ready to go on. Should be the last of the major suspension work, aside from fixing diff leak.
                  Just today, I got the new front soft top seal installed. Took a bit, especially for the front bit, but I got it. Used a credit card to slide the foam in, looks good and should hopefully seal well!
                  • mjweimer
                    • Dec 2015
                    • 648
                    #39
                    Catching up on your build thread....you have done a huge amount of work and it is coming together really well! How badly broken is the cable for the soft top lid? There are many bicycle brake cable repair kits out there that might be able to help you repair it....otherwise finding a someone parting an iC would be the best option.
                    Also, great info on the E39 t-stat housing, should make bleeding much easier since it is at the high point of the system. Price seems right too....I'm going to change mine over to this part when swap radiators....Thanks!
                    • 128keaton
                      • Apr 2020
                      • 115
                      #40
                      Originally posted by mjweimer
                      Catching up on your build thread....you have done a huge amount of work and it is coming together really well! How badly broken is the cable for the soft top lid? There are many bicycle brake cable repair kits out there that might be able to help you repair it....otherwise finding a someone parting an iC would be the best option. Also, great info on the E39 t-stat housing, should make bleeding much easier since it is at the high point of the system. Price seems right too....I'm going to change mine over to this part when swap radiators....Thanks!
                      Thank you! It’s been a really great project to have. It’s not terrible, I don’t even think it’s frayed. The big problem is that it’s the end that’s broken off the cable, it broke right at the base. I’m wondering if I can solder it or weld it, I’m just surprised there isn’t a known solution already I guess. Seriously! No drama bleeding now, hope it goes as smoothly for you as it did for me. Sent from my iPhone using Tapatalk
                      • 128keaton
                        • Apr 2020
                        • 115
                        #41
                        Had a little ouchie on Sunday rolling around town:
                        I
                        Went right into the back of someone who stopped way beyond the yield sign.
                        Didn’t get totaled, got a check three days later. Ordered new core support, new euro valence, lip, and a euro bumper kit. Figured I could use these parts and the air dam on my sedan project.
                        I have a spare fender for that side, just working on sourcing euro grilles again and hood/hinge.
                        Since I’m pulling the front off and replacing the radiator again, I’m going to try the euro E36 fan with my SPAL pusher to see if I can have reasonable temps all the time.
                        • Panici
                          • Dec 2009
                          • 2570
                          #42
                          Originally posted by 128keaton
                          I received a plastic dash cap, thought it looked pretty good. This is a pic of it just sitting on top.
                          One of the better dash pads I've seen! From a distance you can't even tell it's on there.
                          I then replaced the seal plugs in the trunk which were drilled/knocked out when I pressure washed the trunk area.Just pop them in the hole and run a heat gun on them until the wax melts a bit.
                          I have done this on my car, but wasn't aware there is a wax component to melt! Thanks for the info.
                          Oof sorry to hear that. Glad you are okay and you have a plan to fix the E30.
                          Will be following your thread for updates!
                          • 128keaton
                            • Apr 2020
                            • 115
                            #43
                            Thanks! I’m working on restoring a dash for the sedan instead of capping it, just to learn:
                            Anything can be fixed with enough time and money!
                            • 128keaton
                              • Apr 2020
                              • 115
                              #44
                              How it started:
                              And after some tweaking and hammering:
                              Really ready to remove the core support and get this thing 100 percent straight. More than likely I’ll be needing to replace the headlight bracket on that fender. Somehow both the SPAL fan and the AC system survived the wreck making this the 2nd wreck the SPAL fan has survived.
                              Still waiting on the parts to arrive to begin actually welding the car back together.
                              • Codym42
                                • Mar 2013
                                • 611
                                #45
                                Man, love all the work you've put into this car. The interior looks great!! Did you glue the dash cap on? I've been thinking about getting one but I'm afraid to glue it down in case it decides to warp or something.
                                Sorry to hear about the wreck but glad to see you're putting it back together. Do you have classic car insurance?
                                '90 325i - 5 speed coupe
                                '05 330ci 6MT ZHP
