s54 carbon airbox
  • anaphe
    • Jan 2010
    • 56
    s54 carbon airbox
    I am trying to find the best way to fit the Turner airbox (carbon) on my e30 m3 s54 swapped race car.
    The car has been racing like this for 10+ years and everything works really well so I would like to change as little as possible.
    Click image for larger version  Name:	Screenshot 2024-11-26 at 6.43.02 PM.png Views:	0 Size:	155.7 KB ID:	10130899​
    The airbox snorkel and the upper rad hose want to occupy the same space. I think there are 3 options:
    #1 Weld a hard union at 90 degrees and run a straight hose
    #2 Different radiator (maybe a z3M) with conventional hoses
    #3 Go with a custom radiator or the Chase Bays tucked rad option
    #4 Break out the sawzall and hole-saw......#becauseRaceCar
    Click image for larger version  Name:	Screenshot 2024-11-26 at 6.48.08 PM.png Views:	0 Size:	157.2 KB ID:	10130900​
    I am not sure #1 or 2 will give enough space to clear without clearancing the trumpet of the snorkel. I like option 3 the least as on the race car there are a bunch of items (oil cooler, P/S cooler and ducting that will all be effected and given the car is dead reliable and fast I am hesitant to change what is basically a very good and proven package.
    Does anyone have a definitive solution for the Turner box and e30 / s54?
    Thanks
    Anthony
  • moatilliatta
    • 6152
    Ill start with my thoughts.
    I don't care to much for the Turner box, The Bimmerworld supplied boxes have shown to make good power.
    The Bimmerworld supplied boxes can be plumed better to a high pressure area.
    The E46 Radiator M radiator is smaller than the E36 M radiator.
    I don't think these cars need bigger radiators, just better aero. (Inlet & Exhaust airflow of the coolers)
    Chase Bay radiator may not be as efficient, Weight is further forward and now a new cooling pack is required.
    Can you move the engine back? My answer is in the second line.
    @Zakspeed_US
    • Panici
      • Dec 2009
      • 2566
      Seems like cooling is always a huge concern for a track/race car.
      If your cooling setup is working well, I would be hesitant to swap/modify it, unless you are okay with potential issues arising.
      I would personally be more concerned with sucking hot air off the back of the radiator with the current intake location.
      I saw a significant IAT increase on my datalogs when running an unshielded cone filter. I even switched to a GM IAT sensor, and then pivoted the filter up into clean air (hood was off) to confirm my results.
      EDIT:
      Specific details in Post 290 of my build thread:
      • TobyB
        • 5290
        Heh... I was going to say I'd never had much trouble with cooling...
        then I thought, 'well, except for the brakes, that is...'
        What class does a 3.2l E30 run in?
        My experience has been that
        airflow and plenums (plenae?) matter far more than
        the path the coolant takes.
        Adding some volume (as in, 'it's not a pretty elbow, but it's big enough not to be a restriction')
        never messed with cooling, whereas the bigger airbox idea murdered lap times to the point where we
        ran without one for a weekend, dust, rocks and ducks be damned.
        So I guess, if you've proven that air box, (or others have) then I'd mess up the water flow
        before I messed with the air flow...
        that said, the 'bigger airbox' had a 'perfessinal tooner's' name on it, and was made of Farbin Kaiber, too.
        the replacement is buttugly, made of fiberglass, and is as fast as just trumpets, no airbox.
        t
        it's science, but it's pretty finickey science...
        • anaphe
          • Jan 2010
          • 56
          I ditched it. Will keep the box for a e46/s54 project. like Panici said. I don't really think the change of intake sound was worth reworking a car that has otherwise been bullet proof.
          • moatilliatta
            • 6152
            You don't need to rework the car, you just need the correct airbox.
            How does your current airbox fit? Did you move the booster?
            Street car - The choice is emotional.
            Race car, Do you need 10HP?
            @Zakspeed_US
            • anaphe
              • Jan 2010
              • 56
              No booster dual masters
              current air box fits fine
              • TobyB
                • 5290
                uhhh, this isn't a question- always more, always!
                t
                otherwise, why go?
