M54 DME options
  • hoveringuy
    • Dec 2005
    • 2747
    Originally posted by Sagaris
    Most likely, Theres an M54B30 with trans and 110k on Milwaukee (Thats WISCONSIN you crazy PNW'ers) Craigslist right now for $600
    $600... wow, if it's not an overheated motor that's a good deal even without the transmission!
    Plenty of M54's were overheated because their related cooling systems (radiator, expansion tanks) in the chassis sucked. Beware!
    • Andrew325is
      • Jan 2008
      • 1212
      Wouldn't you have to get the stock M54 ECU reprogrammed just like the S54 ECU to disable things like DSC and CAN-bus besides just dealing with EWS before using it in a E30?
      Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
        • 34844
        sort of, maybe..
        • Roysneon
          • 4505
          Originally posted by nando
          sort of, maybe..
          Well now this has me concerned about being able to use the stock engine controller from the M54 if the EWS and other unused features can't be removed by a reflash from an established tuner.
          Originally posted by mbonanni
          I am a pursit now.
            • 34844
            They can be, for sure.
            • 328ijunkie
              • May 2007
              • 3961
              It would be fine.
              Check Us out on Facebook
              Full Product Line Tuning
              • moatilliatta
                • 6152
                So who can delete ews on ms43? Euro II reflash will take care of the emission tid bits.
                @Zakspeed_US
                  • 34844
                  Im sure mark d can, or you could just install it if your dme came with the module & key.
                  • DesertBMW
                    • Aug 2011
                    • 1042
                    I can delete EWS 3.3 and other components that are not needed for swap. And M54 will work fine in your E30
                    • harv
                      • Nov 2004
                      • 555
                      Post by mistake.
                      John
                      The Revolution will not be televised.
                      • Gruelius
                        • Oct 2009
                        • 298
                        bump, so can the stock ecus be made to run in a e30 without much stuff
                        RIP 84 323i coupe 5spd w/ 14psi
                        89' 318i
                        • hoveringuy
                          • Dec 2005
                          • 2747
                          You will need all the EWS stuff.
                          • RobertK
                            Kicked cancer's ASS.
                            • Jun 2005
                            • 5864
                            Originally posted by 328ijunkie
                            Stock ECU w/ EWS flashed out.
                            Thread:
                            I second that. Preferably a MS45.1 if you plan to run ZHP cams.
