Just shipped an S54 adapter harness to Australia!
Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
Originally posted by jrods View PostAndrew i would like to ask you what are my options as far swaping
an s54 into a e34 535i 1992. I know that this is not a common swap
but that is the way i want to go. what could be done with wiring
harness and ecu on both cars.
Thank you for your help
J rod
Originally posted by disboifromja View Postlooking for a e30 swap harness s50 swap
I cannot say enough good things about this guy.
I ordered an E30 M50 adapter and I have to say I'm impressed. The adapter looks like it was made by BMW themselves. Not only the item quality is superb, the communication is just as amazing. All the information regarding the car and the engine went through and he even supplied me with an extra diagram related to the A/C. He packed it, insured it and still came out cheaper than retailers. I feel safer when someone actually builds something around what I have other than just shoving an adapter into my face.
I cannot recommend Andrew enough! All I can do is bump the thread and spread the word :)
Unfortunately I cannot try it yet and probably not for some time seeing as my E30 is going through some major body work.
Email sent ;-)https://www.forabodiesonly.com/mopar...re-irs.356333/
Andrew325is, can you build a harness for M60 harness to 1987 325is built in 2/87. What is the cost?sigpic
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
Originally posted by alco View PostAndrew325is, can you build a harness for M60 harness to 1987 325is built in 2/87. What is the cost?
I've just received feedback that the ring terminal I've been supplying for the starter terminal 30h (field terminal) on the S54 adapter harness is too small to fit over the bolt stud. My apologies! I will now supply a larger terminal. But for those who have the smaller one, you can connect it to any ground point instead of the starter. Or you can use a conical file to enlarge the hole or snip it off and crimp on a larger ring terminal.
