E30 M54 Swap Guide
This is a sticky topic.
  • Staszek
    • 2533
    #61
    Originally posted by bmwmaster81
    I have heard that a e90 break booster should be fine.
    E90 really? this is the first time I heard that one, details?
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      #62
      Yup. Barry is running one in his car and it works fine.
      • Staszek
        • 2533
        #63
        Is it smaller? That part is way easier to get new, I would go with that if it fits!
        • RobertK
          • Jun 2005
          • 5864
          #64
          Its a little smaller and so is the master. Felt great when I test drove it. Pretty easy to install too.
          • Staszek
            • 2533
            #65
            Is it smaller then the 2002, that would be awesome and more readily available, so he used the E90 Master as well hmmmmm, I am liking this.
            • evoDRichie
              • Jan 2010
              • 1743
              #66
              I think I may do a swap into my e24!
              • wazzu70
                • Jan 2005
                • 1143
                #67
                Looks like the E9x brake booster is about 8" diameter and looks to be deep enough to be dual diaphragm.
                -Nick
                M42 on VEMS
                • Staszek
                  • 2533
                  #68
                  Hmm let me check the 2002 one I have.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    #69
                    That would be interesting to know, not sure what diameter the 02 booster is.
                    The stock E30 booster (non-ix) is 10" diameter. IX/E32 booster is 9"/8" diameter.
                    -Nick
                    M42 on VEMS
                    • hoveringuy
                      • Dec 2005
                      • 2700
                      #70
                      Since this is the M54 swap guide, is anyone running an M56 SULEV aluminum valve cover with the integral CCV?
                      I want...
                      • FredK
                        • 14759
                        #71
                        Hey, did you get a chance to measure the diameter of the 2002 booster you have?
                        The E9x booster sounds intriguing!
                        • Staszek
                          • 2533
                          #72
                          Not yet I have been traveling, but thanks for reminding me, I will when I get back on Wednesday.
                          • cwlo
                            • Sep 2015
                            • 131
                            #73
                            2002 is 8" in diameter. The e90 booster looks like a nice option. Brake lines will need to be modded to go on the other side of MC.
                            Chris
                            • FredK
                              • 14759
                              #74
                              Nice. It appears that the E9x booster will be a tight fit! The booster does use a compact master cylinder, but even then, overall length of the booster + MC will be tight!
                              Anyone have pictures of an S54 being used with an E9x booster/MC?
                              • cwlo
                                • Sep 2015
                                • 131
                                #75
                                E90 Booster
                                So I was able to install the e90 booster. It was a tight fit getting it in. I needed to move the fuse box over, remove DISA, and lift that side of the engine up an inch or so to get it in. Fits like a glove. The reservoir will interfere with the DISA, so I am looking into solutions....could do remote, modify existing reservoir, or find something that will fit. Since the E90 Mcylinder has the outlets on the wrong side, I ordered a used X3 MC that has the right side outlets, and is looking like the existing lines might even fit with a little persuasion.
                                So far, seems like one of the better solutions, as the parts can be found cheaply on ebay, and the booster should have better capacity than the VW/944/2002 ones.
