Arc Asylum subframe
  • Northern
    I like cupcakes & sh!tboxes
    • 5220
    #46
    I took a look when I changed the oil yesterday, mine's mounted on top as well (predates the reinforcements)
    Originally posted by priapism
    Originally posted by shameson
    • Holland
      • Nov 2008
      • 7178
      #47
      Glad to see the new design redivision. I will be getting in contact with you soon to have my subframe done as well.
      Originally posted by DEV0 E30
      • bmxmett318
        • Nov 2005
        • 47
        #48
        Originally posted by Northern
        I have an IE 25mm sway and it's still higher than the rack/subframe... Are you sure that's an E30 swaybar? It really doesn't look like it is.
        Also, another plug for Tyler's communication... Over 75 emails back and forth for my pan/subframe/pickup/xbrace and I've never had an issue.
        Don't try to contact people through weird methods, and you shouldn't have a problem.
        Did you say brace???! I've been asking about one for past 1.5 years!!! ;)
        • Northern
          • 5220
          #49
          Still haven't test fitted it. I've been meaning to get around to it soon, and then paint it after I know it fits around my exhaust setup.
          • TinyT
            • Jan 2011
            • 152
            #50
            Just an update on parts.
            Although I haven't been able to get a fully fabricated piece into production, the subframe modifications have been revised even more. They include much stronger sway bar mounts which place the bar on top of the new mount, between the frame rail for better clearance.
            • Staszek
              • 2533
              #51
              Cant wait to get mine!
              • butters
                • 1202
                #52
                Tyler I sent you an email. My swap isn't running yet and I haven't mounted up my sway, I'm curious what it would take to exchange my subframe for the revised version...
                • TinyT
                  • Jan 2011
                  • 152
                  #53
                  No problem, replied to your email
                  • Staszek
                    • 2533
                    #54
                    Tyler,
                    One question on the last picture, is the sway bar mount touching the frame?
                    • TinyT
                      • Jan 2011
                      • 152
                      #55
                      Originally posted by Staszek
                      Tyler,
                      In that pic maybe, it's just thrown in there for a quick picture without the mount seated in its pocket and not bolted in. The answer for this setup is no it doesn't touch with Ireland 2 bolt mounts.
                      • R3Z3N
                        • Jan 2011
                        • 3056
                        #56
                        Tyler, thanks for updating the subframe with top mount and more bracing! Looks great! Unfortunately I already cut mine off and am welding a reinforced bracket to the existing chassis rails right at the ~45ยบ part upper bend, but this is what I wanted in the end anyway for an in car adjustable blade setup on bearings.
                        Evolution of a part at its finest! BTW I will have a trans brace to loan you for the GS6-37BZ/DZ (6 Speed WAY more common and cheaper) to copy for use with the E90 trans mount if you want shortly enough so that people have another easy option along with correct length shifter linkage for said setup for AKG DTM shifter.
                        • Staszek
                          • 2533
                          #57
                          Thanks Tyler, I was able to get my oil pan off today. I will probably ship tomorrow.
                          • stonea
                            • 2892
                            #58
                            Wow, I really like the design of the updated subframes. Definitely gives more more confidence to go rear sump for my M54 swap.
                            My Garage
                            Feedback
                            Instagram: Stone.Hopkins
                            • cwlo
                              • Sep 2015
                              • 131
                              #59
                              I'm not sure Tyler is doing m54 setups anymore. Given all the problems I encountered not sure I would recommend his stuff to others.
                              Chris
                              • Staszek
                                • 2533
                                #60
                                Chris
                                What problems
