944 VS 2002 Booster
  • Shftr8
    • Aug 2014
    • 530
    #31
    does anyone have any pictures of the 2002 booster installed with a S54??
    • BMW_TUNER
      • Jul 2006
      • 1386
      #32
      1989 332IS -S-Fiddy Four-Some weight removed.
      5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
      • Staszek
        • 2533
        #33
        But where can we get one? Also what was the part number for the 944 booster?
        • BMW_TUNER
          • Jul 2006
          • 1386
          #34
          I will have a 944 one up for sale but rock auto had the 2002 one.
          • Staszek
            • 2533
            #35
            Bought the last 2002 one from Rock, thanks for the help!!
            • Dagamus(NM)
              • 621
              #36
              Didn't see your listing but that should work nicely for my needs. PM me with details please
              Gun control means using both hands
              Sex, Drugs, Rock 'n roll. Pick two.
              • BMW_TUNER
                • Jul 2006
                • 1386
                #37
                944 vs 2002
                • Staszek
                  • 2533
                  #38
                  944 vs 2002
                  944 looks quite a bit smaller, less assist I am assuming.
                  • BMW_TUNER
                    • Jul 2006
                    • 1386
                    #39
                    Its thicker so maybe not.
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      #40
                      Modification was easy and the new part is already in.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #41
                        Was there much change in pedal feel (assistance)?
                        john@m20guru.com
                        Links:
                        • BMW_TUNER
                          • Jul 2006
                          • 1386
                          #42
                          No vacuum to be applied right now but I will let you all know. The modification was so simple I didn't even take pics. You simply cut the existing clevis and weld the OEM one on top at 130mm to hole center from the base.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #43
                            Run a hose from another car :p lol
                            I have done many swaps with various boosters, so the mods don't scare me - more interested in pedal assist right now. Have an s54 swap coming up soon at work, but the client has a mix-matched set of BBK's and have a feeling we will need a decent amount of assist, probably a larger master as well. With stock e30 brakes I have done the 740, ix, 2002, Audi, 944 boosters, as well as a couple Massive deletes. This all changes when the car has Wilwood 4 pot rears and Forge 6 pot front calipers, though. :/
                            john@m20guru.com
                            Links:
                            • BMW_TUNER
                              • Jul 2006
                              • 1386
                              #44
                              Yeah mine should be a pretty decent indication of braking assist. I have E36 M3 front brakes and 318ti rears with at 25mm master.
                              • TobyB
                                • 5293
                                #45
                                iginally Posted by BMW_TUNER View Post
                                944 vs 2002
                                2002 booster on left, btw.
                                t
                                having had a few 2002s...
