N52 routine maintenance item
  • hoveringuy
    • Dec 2005
    • 2733
    In addition to replacing my valve cover last week (I used Rein which seems to be identical to OEM..) I also performed BMW Service Information Bulletin SI B11 07 14 which says that the VANOS attachment bolts need to be checked and replaced. The original design of the bolt had the security pin in the middle that somehow made it prone to sheering, people would find the bolt heads in their oil pans. The replacement bolts have a new design and are $0.22 each at BMW. GET EXTRAS! They are very shallow and don't always grip. Installation torque is 6NM+60 degrees. They're aluminum, naturally...
    None of mine were broken.
    Also do your Oil Filter Housing gasket!
    Click image for larger version  Name:	Capture.jpg Views:	0 Size:	176.4 KB ID:	10111940
  • moatilliatta
    • 6151
    Those front head bolts can pop off also. A few which are below the valve cover up front.
    @Zakspeed_US
    • Caperix
      • Feb 2018
      • 194
      There is a 2nd vanos recall getting ready to drop for the bolts loosening, so checking them is a great idea. As is checking the bolt heads at the front of the cylinder head for breaking off. Cars with the 3 stage intake should check the disa flaps as they can break off as well. The pcv heater has been recalled multiple times, once to replace the elbow under the intake & a second to add a fuse to the circuit. The water pumps are getting better but I would replace the water pump & thermostat on a junkyard engine.
      • Striker01
        • Jul 2011
        • 375
        Too bad I didn't I didn't know to check these when I did the valve cover gasket. Now I wonder if I should order MILVs if I'm going to have the cover off again.
        • hoveringuy
          • Dec 2005
          • 2733
          I wasn't clear on the "bolts at the front of the cylinder head". We're not talking about the M10 cylinder head bolts are we, the ones that keep compression where it's supposed to stay? Or are these smaller accessory bolts that clamp it to the timing cover?
          I didn't see anything out of place, in any case.
          • Caperix
            • Feb 2018
            • 194
            The e torx bolts that hold the head in the timing cover area. The heads tend to break off, the vanos units need to be removed to get 2 of them.
            • Striker01
              • Jul 2011
              • 375
              hoveringuy​, I have the same bolts in your picture but the original recall part number is NLA. Seems BMW doesn't have a solution for these right now. The donor car VIN is in the 23V-707 recall. Another hurdle for this swap.
              23V-707.PDF
              • hoveringuy
                • Dec 2005
                • 2733
                Striker01 P/N 11368602263 . Looks like they're backordered at Bimmerworld but Pelican and a few other places say they're available. If you have all 8 in place it's not an emergency but something to do later.
                • adam.nonis
                  • Apr 2017
                  • 755
                  I have a set of (10) of these you can have Guest. Just give me a mailing address. I got a set for my engine, but I have a different rev and don't need them.
                  Sent from my iPhone using Tapatalk Pro
                  • Striker01
                    • Jul 2011
                    • 375
                    [QUOTE=adam.nonis;n10117486]
                    I have a set of (10) of these you can have Striker01. Just give me a mailing address. I got a set for my engine, but I have a different rev and don't need them. /QUOTE]
                    Thanks,
                    sent you a PM
                    • hoveringuy
                      • Dec 2005
                      • 2733
                      I borescoped the motor for absolutely no reason (adam.nonis )
                      I've got somewhere around 9X,000 miles on it now and 3-4 years of solid track time. I haven't taken any compression or leakdown readings, it does smoke a little on initial start after it's been sitting.
                      There's light piston scuffing on all cylinders. Valves look good, #6 piston crown looks slightly oilier and has more carbon than the others. Visible oil trail on #6 wall. (from where...?)
                      Reading the Porsche forums on their Lokasil bore scoring issues, they obsess over this. Some say there is no limit for scoring, some say all Porsche Lokasil engines have some scoring.
                      I'm not going to worry about it.
ID:	10136975 Click image for larger version
ID:	10136976 Click image for larger version
ID:	10136977 Click image for larger version
ID:	10136978 Click image for larger version
                      • adam.nonis
                        • Apr 2017
                        • 755
                        This would be the “no reason” he mentions
                        • hoveringuy
                          • Dec 2005
                          • 2733
                          Here are some better pics....
                          Click image for larger version  Name:	Capture.jpg Views:	0 Size:	185.1 KB ID:	10137618 Click image for larger version  Name:	Capture2.jpg Views:	0 Size:	169.2 KB ID:	10137617 Click image for larger version  Name:	Capture3.jpg Views:	0 Size:	179.3 KB ID:	10137616
                          • DesertBMW
                            • Aug 2011
                            • 1038
                            another proof these engines are "one time use"
                            • hoveringuy
                              • Dec 2005
                              • 2733
                              If it gets this bad it's just not economical to rebuild: there are just so many of these motors floating around.
                              Otherwise the bearings can be replaced, new cam ledges, even the Alusil can be honed and restored easily
                              The replacement to this one had ~100,000 miles and runs amazing!
                              (change your oil frequently, kids!)
