Six Speed Trans Options
  • Yo.goob
    • Mar 2024
    • 19
    Has anyone confirmed any other rear differential fitments aside from the stock E30 diffs? Looking for the best option since I'm using the GS6-17bg and no longer using the small case 4.10 that came with my 318is.
    I know Striker01 using a custom shaft significantly simplifies the need for any other modifications to the rear diff, just not sure if any other options exist
    • Striker01
      • Jul 2011
      • 380
      I don't know, using my stock medium case.
      • TobyB
        • 5298
        If you're keeping the E30 subframe, then you're pretty much tied to the E30 case- the flange ears on the front of the diff are unique to the E30.
        t
        • Ifixjets
          • Jul 2025
          • 1
          Does anyone know if the Getrag 260 will bolt up to the N52? I live in Hawaii and I don't have other transmission options locally. I have a '86 325e and I'm trying to plan my engine swap and there is a crashed '06 X3 3.0si for cheap that I could use.
          • hoveringuy
            • Dec 2005
            • 2754
            No, not like any DOHC motor before it, won't mate to the G260
            • Caperix
              • Feb 2018
              • 195
              The transmission mounts are close but there is an extra bolt compared to the m20 & m5x. Adapter plates exist for zf8/dct to m5x so you may be able to use them backwards.
              • TobyB
                • 5298
                Isn't there a starter motor issue, too?
                An E46er who adapted an 8hp had a whole saga of having to
                get the bellhousing welded to hang the starter for the M5x engine...
                t
                wants an N52 and an 8hp in his e39 wagon...
                • hoveringuy
                  • Dec 2005
                  • 2754
                  8HP has been done by multiple people now for the N52, it's native to that motor.
                  https://www.e90post.com/forums/showt...#post32134096n
                  • Caperix
                    • Feb 2018
                    • 195
                    8hp was used in early f10's & f25's with n52's. They all used the msv90 ecu, not sure if those have been hacked. But there are plenty of aftermarket controllers for 8hp that you could probably run anything.
                    • TobyB
                      • 5298
                      Guess I need to start shopping for a rear- ended 2010 528i, huh?
                      Yeah, I must be getting old, but what excites me about this project is
                      programming the 8HP to do what I want it to do. Really? I want to
                      play with an automatic transmission???
                      yup, get off my lawn....
                      From what I've gathered so far, I can run the N52 on a BMW- native DME,
                      but the transmission is going to have to be run by something like the Turbo Lamik
                      controller, simply so I can have control over all of it?
                      oops, threadjack.
                      I blame that darned cloud.
                      t
                      • hoveringuy
                        • Dec 2005
                        • 2754
                        oops, threadjack.
                        This belongs in the 8-speed options thread? I can't wait to see the first 8hp e30 with an N52!!
                        • TobyB
                          • 5298
                          even worse- I want to do this to my E39 wagon.
                          Because an LS swap is so... booorrriiinnngggggg....
                          and too generically old- guy hotrodder.
                          t
                          • hoveringuy
                            • Dec 2005
                            • 2754
                            t
                            If only someone could figure-out how to slap a roots blower on an N52....
                            adam.nonis
                            • adam.nonis
                              • Apr 2017
                              • 755
                              adam.nonis
                              This will be a completely 'nother thread. Can't wait to block the silencer ports so I can sound like a Hellcat.
                              Sent from my iPhone using Tapatalk Pro
                              • Striker01
                                • Jul 2011
                                • 380
                                You'll need the whistling exhaust manifolds to, if that's what your going for
