BAR’d N52 swap. Will I be the first?
  • benz-tech
    • Jan 2011
    • 382
    He was being overly strict on some evap rules. If I I ‘modify’ fuel sensors to work in my tank then that’s ‘modifying’ the emissions system. I argue that everything in the tank is part of the evap system where the law states that components can be integrated to use with the full functionality (DTML) of the new system. Different coding will change the calibration number I believe, so that’s a no-go. I just read some diagrams yesterday and realized I need the JBE for the fuel level and at least two other modules. I can wire them with minimum 15, 30,31 and CAN, plus any needed sensors. This will no-doubt be stupidly complicated. If I get to the ‘impossible’ point, I’m humble enough to throw in the towel. I’m not there yet but it’s getting close. This might end up being a nice 6spd to put behind my 4 banger that I hate.
    part of me thinks that if I show up with a very clean install including airbox and cats, all the monitors run and a clean dyno run with an e90 instrument cluster with a functional check Eng light and working speed and fuel gauge that I would get the thumbs up.
    You say "Where are your other two cylinders?"
    I say "Where's your other camshaft?"
    Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
    • benz-tech
      • Jan 2011
      • 382
      Small update. Got my DME and CAS married. Car starts and runs great. I think an N52 will feel like a powerhouse in a e30
      • hoveringuy
        • Dec 2005
        • 2752
        Spoiler alert: it will ;)
        • benz-tech
          • Jan 2011
          • 382
          And while fitting an E90 tank is right out (too wide both longitudinally and transversely),some initial measurements on a 1-series tank show some hope. Haven’t committed to the fuel tank thing yet but still pursuing options.
          • benz-tech
            • Jan 2011
            • 382
            Good, because I’m tired of slow cars.
            • Ty_Bo
              • Aug 2021
              • 8
              Working on prep for mine, I'll race you to making the engine run, then evap happy.
              As far as BAR goes, your ref seems to be overly harsh on evap for an OBD1 car. If you can make the car run and pass monitors on the DME, you're done. Good notes on the DTML, I need to look deeper into it and probably make some junkyard runs.
              CATs do need to be as close as possible to factory location to keep refs happy. The process isn't very standardized but it is rigid. Most of my experience is helping friends with E-rod swaps (EO number, much easier) and they have a lot of experience with M50 BAR swaps. N52 seems like it's reasonable to get it to run but challenging to follow through on the BAR sticker. Rooting for you, but there will probably be some fabrication involved on the car to get the CATs where they need to be
              • benz-tech
                • Jan 2011
                • 382
                ill bet you’re done first. But after driving the 328, I’m convinced this will be an amazing swap and worth the effort. Got the donor to pass all monitors. Next I will delete dsc functions to a minimal level and see if the cluster still reads speed and dme is happy. If I read correctly the right rear is where the speed input comes from. Basically I will start unplugging things to get down to a basic elec system Then I’ll clear the monitors and see if they will re run. The moment my registration shows up I will smog my e30 on the old engine then start the swap. This will give me two years(not that I’ll need it) before it has to go back to a smog shop.
                • Caperix
                  • Feb 2018
                  • 195
                  There is a direct wire from the dcs to dme for wheel speed on MSV80 as well. I found out chasing a check engine light due to vehicle speed. If I remember it was a DC signal so I'm not sure if the factory speed sensor in the E30 diff could be used or not. Looking at wiring diagrams it is from pin 8 of the DSC to x60001 pin 17 of the DME labeled rr whl out.
                  • benz-tech
                    • Jan 2011
                    • 382
                    I verified that there are no fault codes in DME and no traction intervention with only the right rear wheel speed sensor attached. Next step will be just to disconnect the DSc and see if that sets a ‘CAN with DSC’ fault code. I can at least run a DSC on minimal inputs and have normal DME function.
                    • benz-tech
                      • Jan 2011
                      • 382
                      Progress! Got the E30 wiring harness made. DME, CAS, DSC, IC, JBE and needed sensors etc. Everything else has been removed. It starts, runs, has throttle response. Engine is still in the e90 chassis but I’ll pull it in the next week or so.
                      • DesertBMW
                        • Aug 2011
                        • 1043
                        I bought 2010 328i then stripped it all to bare essentials, it didn't need to have speed sensor or DSC attached at all to have full power.
                        • benz-tech
                          • Jan 2011
                          • 382
                          You’re probably right but I want to run the E90 speedo and will need it to run monitors in DME. I also picked up a spare engine with a busted cam gear. So now I have a bed plate for oil pan fabrication.
                          • benz-tech
                            • Jan 2011
                            • 382
                            Significant progress now. I fit my junk block (for oil pan creation) and the good trans to get pan fitment, mounts, driveshaft length etc before the good engine goes in. Stock M42 mounts at the moment upside down so I had full range to spin them. Looks like I need a taller pass side mount to get the shifter positioned correctly.
                            driveshaft splines are the same so I can use a shortened e90 front -after I find out if the csb will slide on the bearing- and the e30 rear driveshaft. Engine is pretty far to the rear with my m42 mounts. Cats might clear the firewall but will be close.
                            Is the e28 535i pass engine mount the solution for the correct twist?
                            • Striker01
                              • Jul 2011
                              • 380
                              That shifter position looks right for the Z4 engine arms and 24v AKG mounts. I think all of us who've done this swap shortened the shifter carrier and shifter arm. Its not difficult.
                              • benz-tech
                                • Jan 2011
                                • 382
                                Some good progress lately. I received my ‘97 e36 driveshaft and mated it up to an x3 front section for perfect driveshaft fitment. I had already ordered revshift mounts when I read that they don’t work. Interestingly I used the right revshift mount and the left M42 mount. Both upside down and both using the slot instead of the hole in the subframe. Engine is centered and aligned perfectly. The front section of driveshaft lines up perfectly in the center of the csb opening. I’m obviously NOT a photographer
