iX wheel thread
  • kslbo308
    • Jun 2015
    • 42
    #226
    Another Nebraska e30 guy. Sweet!
    Yup in kimball :-)
    • 2002tiiguy
      • Jul 2013
      • 467
      #227
      Originally posted by aaron325ix
      Thanks for that. Got the flares off and yes all the clips broke. I assume once I roll them the holes underneath the lip will be useless as the plastic will need to be trimmed away anyway, correct? I will still use the holes on the outside of the fender to mount them back on right? I see what you mean about that tape, its pretty strong.
      As far as tires, I have been looking at some calculators to compare sizes.
      The current set up: 215/45/17 sidewall height= 3.81 rev/mi= 819.7
      Considering : 225/40/17 3.54 837.7
      225/45/17 3.99 808
      Stock: 205/55/15 4.44 845.1
      Still trying to decide between the 40 or 45's in the 225 width.
      On one hand the 40 is closer in revs/mi as stock so my speedo will be more accurate again, but shorter sidewall than my current set up which means it may not rub but then again I don't want lower profile tires.
      I think the 45's might look better and be less jarring over bumps but I'm afraid they might rub even if I roll the fenders.
      Someone push me in the right direction.
      I loved my rk's but they were cracked, i ran 205/45r17's nice square stance on the wheel and left a little cushion
      • ThatM20Guy
        • Aug 2014
        • 600
        #228
        I know this has probably been covered before but would 16x8 et20's work?
        89' 325ix Diamantschwarz/Black rattle can...
        Insta: r_moose_w
        Originally posted by flyboyx
        I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
          • 34847
          #229
          no. not unless you like extreme poke and lots of rubbing.
          • ThatM20Guy
            • Aug 2014
            • 600
            #230
            Would I have to run like a 30-35 offset?
            Insta: r_moose_w
              • 34847
              #231
              yep!
              • Chrisbike
                • Mar 2015
                • 688
                #232
                Hey R3V, Riken Mesh wheels 15x6.5 et35. I'm pretty sure these will be fine since it's a 6.5 inch wide wheel. I have some Falken Azenis 205/50/15 to match. This is my >$200 autoX wheel and tire setup and I don't want to or plan on rolling fenders/ trimming the IX Bodykit. I have the tires but haven't purchase the rims yet. If anything is a red flag let me know! Also what's the biggest tire that would fit on a 6.5 inch rim? Would a 225 work if I decided to do all of that and get a bigger tire?
                Build Thread
                https://www.r3vlimited.com/board/sho...d.php?t=419655
                Parts Thread
                https://www.r3vlimited.com/board/sho...d.php?t=408302
                  • 34847
                  #233
                  6.5 is a bit narrow. I wouldn't run more than a 205 on that. It will fit just fine though.
                  • Chrisbike
                    • Mar 2015
                    • 688
                    #234
                    Ok that's what I figured. If I decide to go bigger then I'll be using a wider rim with higher offset. I think.. Thanks Nando!
                    Build Thread
                    Parts Thread
                    • litu
                      • 849
                      #235
                      Here is my new ix prefacelift..16x8 et20, front there is adapter 20mm, tyres are 215/45-16. I dont know those spring, but stock shock absorbers.
                      I was roll little those front plastic wheel arch, also there was little rubbing in there m-tech I bumper corner, but i was showing some heat there.
                      At the back there is not adapters, there is made that same thing as was that my red ix, there is those rubber pad to stiff that spring little.
                      In this prefacelift-model has little more room in those arch then facelift, also those plastic wheel arch is better then in facelift model
                      PS, those rims are Rota grid-v, they are meant for frontwheeldrive car, so i need put at least 20mm adapter in front to clear those front brake caliber rack hitting those rims spokes..I will try some day 15mm adapter in front also it need at front because it looks silly now, then that front is way more wider then back, i was thinking like 15mm also.
                      Pss, sorry for those big picture
                      https://www.facebook.com/Cry_77_IX-110483784967661
                      https://www.instagram.com/cry_77_ix/
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        #236
                        So that's a pre-facelift? Is that the '86 in your sig?
                        • litu
                          • 849
                          #237
                          Yes, it is 1986 prefacelift model, my dream car, same as in my sig
                          • Kershaw
                            • 11822
                            #238
                            Isn't the stripe supposed to show where the driver is sitting?
                            AWD > RWD
                            • litu
                              • 849
                              #239
                              I dont have clue what is that stripe point in there..I was bought as such it is
                                • 34847
                                #240
                                nice ix, but the wheel fitment isn't great. that's like ET0 :p
