24V AWD Swap Knowledge Base
This is a sticky topic.
  • LJ851
    • 7919
    #316
    Is it just me or does the transmission to transfercase adapter attachment look really flimsy ?
    Don't the ix models have a lot more beef there?
    Lorin
    The M30 is God's engine.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #317
      That's one of Turk's photos from the V8 AWD M3 thread.
      S62 + 5HP24 bellhousing + Getrag 265 + ZF A110 (525ix)
      • Nisse Järnet
        • Aug 2013
        • 1221
        #318
        Anyone knows what boots might fit the E34 ix axles? The inners seem to fit from E30 ix but not the outers.
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
          • 34844
          #319
          E46
            • Jun 2010
            • 2796
            #320
            I tried to get him to add some locating dowels and such to that, but he didn't get it.
            I guess we'll see if it's effective or not.
            • LJ851
              • 7919
              #321
              If the trans and transfer case were both solid mounted i guess that attachment wouldn't see all the rotational loads.
              Lorin
                • Jun 2010
                • 2796
                #322
                Have you seen the thread? He welded up some scary looking stuff to mount them.
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  #323
                  Originally posted by nando
                  E46
                  Thanks, why didnt i think of that!? :)
                  Link? :)
                    • Jun 2010
                    • 2796
                    #324
                    Originally posted by Nisse Järnet
                    Link? :)
                    More pics/discussion here:
                    But you have to register to view.
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #325
                      Thanks, interesting!
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        #326
                        Oh btw, what exactly was the problem with fitting E46 gear set in a 525ix front diff?
                          • Jun 2010
                          • 2796
                          #327
                          The 525iX gearset has a shorter pinion shank than the E46 gearsets.
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            #328
                            OK i never looked closely at it, can it be fixed without machining a new diff housing?
                              • Jun 2010
                              • 2796
                              #329
                              Since it would involve removing material, you can probably cut down an E46 pinion to fit the E34 case if you have a pretty stout lathe and carbide cutters.
                                • 34844
                                #330
                                it will require more than that. you also have to cut down the ring gear which has to be done precisely.
                                the pinion is about the same length but the diameter of the bearings is smaller on the E34, and the ring gear is thicker.
