Bolt On 325iX Coilovers
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4508
    Does anyone know anything about these?
    Im offiziellen K-Sport Germany Onlineshop finden Sie Gewindefahrwerke, Luftfahrwerke, Bremsanlagen und Ersatzteile für zahlreiche Fahrzeugmodelle. » Jetzt shoppen
  • Nisse Järnet
    • Aug 2013
    • 1221
    Hey that's cool!
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • ForcedFirebird
      • Feb 2007
      • 8300
      I fabricated some coils for Nando's ix. The rear stayed divorced, rather than true rear coils, though.
      john@m20guru.com
      Links:
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4508
        Originally posted by Nisse Järnet
        Hey that's cool!
        Oh, yeah! I want to know how the rear works. I emailed them, I'll update when they respond.
        http://www.e30tech.com/forum/showpos...&postcount=300
        I saw them, very nice! I made some, too! Shorted the housings 2.1" and used a Koni Race insert. Nisse made an extremely similar set up as well.
        Mine:
        Nisse's:
        • EyExR
          • Jan 2011
          • 959
          http://racingshop-germany.com/K-Spor...derbein-hinten
          These look awesome!
          My 325iX DIY Threads:
          Front Wheel Bearing Replacement
          325iX Rear Subframe Bushings and MUCH more w/pics!
          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
          • Nisse Järnet
            • Aug 2013
            • 1221
            I like the divorced, feels better for some reason.
            • Nisse Järnet
              • Aug 2013
              • 1221
              Mine:
              Nisse's:
              http://www.forumbilder.se/DD2OC/dsc-1893.JPG
              Made some socks for mine today :)
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4508
                Good to know.
                • 6A LDY
                  • Jul 2014
                  • 318
                  theres something sexy about true rear coil overs though. they look so... exotic
                  1988 325iX - sold but not forgotten
                  1984 MTech1 323i
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    My understanding is that switching to rear coil overs requires welding reinforcements to the rear shock towers... Is that the case?
                    • litu
                      • 848
                      There is also those normal, you dont need strengthen that back shock tower :)
                      https://www.facebook.com/Cry_77_IX-110483784967661
                      https://www.instagram.com/cry_77_ix/
                        • Jun 2010
                        • 2796
                        http://racingshop-germany.com/K-Spor...ahrwerk-Street
                        Funny that they used a photo of the RWD parts for that advert.
                        Don't need to mod the shock tower?
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          For true coils the rear shock towers should be reinforced. A local had them on his e30 we swapped without the reinforcement and they seem to be holding up ok after a few years, but not sure I would trust them like that.
                          john@m20guru.com
                          Links:
                            • 34844
                            those fronts look interesting, but they don't look short enough, and I don't like the camber plate design. the stack height is too tall so you either compromise ride height or shock travel.
                            the set I had built by ForcedFirebird are superior IMO, and cheaper.. with Konis they ride like a dream. Bilstein can suck my nuts.
                            • nrubenstein
                              • 3148
                              There are two schools of thought on reinforcing the shock tower:
                              The first school points out that it's thin fucking sheet metal held on with a couple spot welds that is known to fail under normal use.
                              The second school says that it totally works fine.
                              The reality is that you *can* run unreinforced shock towers. Of course, you are taking a substantially increased risk that you will will tear the sheet metal. (Also, since it's a weak area, leaving it unreinforced allows a bit of additional movement.)
                              2002 BMW M3 Alpinweiß/Black
                              1999 323i GTS2 Alpinweiß
                              1995 M3 Dakargelb/Black
                              - S50B32/S6S420G/3.91
                              1990 325is Brilliantrot/Tan
                              1989 M3 Alpinweiß/Black
