Sunroof delete reccomendations
  • kelvinj520
    • Sep 2017
    • 29
    Was building a track e30 and was wondering if anyone had any recommendations for a company that sells sunroof deletes.
  • D3’min
    • Oct 2018
    • 28
    • flyboyx
      • 8371
      Jesus! 250 bucks for that? how about dropping the zero off the back end and I bet they will still double their money. I would just make a mold of my own panel and fabricate my own.
      Gigitty Gigitty!!!!
      • D3’min
        • Oct 2018
        • 28
        Or just seal it up and call it a day is it leaking ?
        • varg
          Florida Turbo Man
          • May 2014
          • 3417
          Originally posted by DTMfiberwerkz
          Our Sunroof Delete is about 3lbs which is a huge weight saving over stock.
          :stupid:
          oh wow a piece of plastic is lighter than a metal panel, an electric motor, a set of tracks, a bunch of brackets, etc. who would've thought
          IG @turbovarg
          '91 318is, M20 turbo
          • TobyB
            • 5280
            You still have to cut away the sunroof cassette and supports, which weigh a lot,
            and really suck to remove. Cut, grind, pull, get shit in your eyes, but don't heat
            or punch through or dent the roof itself. Yes, it's welded AND bonded to the roof.
            Then, with all that gone, welding the stock metal roof back in is only an average pain in the
            ass, moderately, and a bit of seam sealer, and done.
            I recall the stock metal panel weighs something like 8 lbs. So I guess in racecar units,
            the 3 lb panel might be worth it. In street car units, not at all.
            t
            • varg
              Florida Turbo Man
              • May 2014
              • 3417
              ^Exactly why I bought a mismatched but rust free panel instead of trying to do a sunroof delete on my car. Even taking the headliner down is more of a can of worms than I want to get into.
              IG @turbovarg
              • kelvinj520
                • Sep 2017
                • 29
                It is leaking.
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  For a track car I think your best bet is a sheet of plastic or metal riveted and bonded to the roof of the car. Also, removing the whole sunroof cassette should be done before you install a roll cage if you're planning to, and as said above it is an enormous pain.
                  • e30davie
                    • Apr 2016
                    • 1788
                    $225 seems alot, but if its contoured like the photo suggests and it matches the roof curvature it is not the easiest thing to make. If its made well it might look pretty decent on a street car.
                    For a track car though, i reckon see if i you can cut the roof off a non sunroof car and employ the use of a pop rivet gun.
                    • e30rida
                      • 963
                      Go to any metal fabrication shop, take the old sunroof and a sheet of sheetmtalr and they will bead roll it for you. They'll charge around $100. The buy a couple of black SikaFlex 221 tubes and seal it in.
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3417
                        Judging by where it comes from, I doubt it will match the roof curvature very well.
                        IG @turbovarg
                        • kelvinj520
                          • Sep 2017
                          • 29
                          Thanks for the advice everyone. I might just remove all of the sunroof junk and then in the end just rivet sheet metal on top.
