Mr Lens fog light lenses
  • Digitalwave
    is a poseur
    • 6299
    None in my hands but I stepped on a piece that bled like a banshee.
    RISING EDGE
    • Hatchman
      • Mar 2005
      • 1425
      yea I've isntallled these too... I fucked one install up a bit but the other came out perfect
      • RCWells
        • 3589
        They look good. Especially if on a budget.
        [THE 501 club - Founding Member]
        • parkerbink
          • Jun 2004
          • 10138
          So you basically break the old glass out or can you heat the fog up in the oven like a smiley? I have a set that are both cracked & look sandbalasted. Whish I had seen this thread last week. I just bought a used set for 110.00.
          Gracias
          btw
          www.mrlens.com comes up not found. anyone have a new addy or somewhere else to get lenses?
          Found a set on ebay with graphic removal/replacement instructions.
          BMW E30 3 SERIES FOG LIGHT LENS SET NEW FOGLAMP is the title.
          • Digitalwave
            is a poseur
            • 6299
            I think the eBay ones are the US distrib. for Mr Lens, but if their site is down they probably went out of business.
            Why would you want to heat the lens off? Its not like you are going to keep them, just smash it out.
            RISING EDGE
            • parkerbink
              • Jun 2004
              • 10138
              Seems it's easier and less dangerous to take it off whole than deal with breaking it off. Mine are solid except for where the rock cracked them.
              • e30evolution
                West Werks
                • 1888
                TJ... if you want to get the lamin-x on without bubbles.... try using soapy water.... clean the lense... dry it and spray soapy water on both surfaces... then use a credit card/squigy (sp.) to get all the water out from under the film....
                but yah... Mr. Lense doesn't work.... who was the seller on ebay if i might ask?
                http://www.westwerksauto.com
                  • 34839
                  go to BMP's website, no dealing with ebay or shady south african companies.
                  • Q5Quint
                    • Jan 2005
                    • 725
                    I want to order some of these lenses, but the ones on bmps website look a bit different~
                    check it out
                    are these the same ones some of you all ordered?
                      • 34839
                      the pictures are wrong, but as long as you're ordering for an E30 you will get the right ones (I got mine there).
                      I would order over the phone to be sure.
                      • Digitalwave
                        is a poseur
                        • 6299
                        check it out
                        Those look like early model fog lenses but I am not sure.
                        RISING EDGE
                        • Jordan
                          • 12916
                          Those ones pictured above are E34 lenses.
                          https://mtechniqueabs.com/
