E30 Audio Overhaul - My Project Details
  • bmwman91
    • Oct 2004
    • 3128
    #121
    Oh, and if anyone wants vector-art copies of the diagrams let me know (.svg format). The CD43/electronics art blocks can be used by anyone else with an interest in making these diagrams. Use them for whatever you want (personal/profit/whatever).
    OK, as promised here are some pics of the final installation.
    The CD43, installed. I have messed with it a little (took it apart, cleaned the optics & checked the springs/dampers) & that helped reduce the skipping. Radio reception is still awful though. If only there was another factory BMW CD player option...
    Tweeters...installed.
    Driver's side mid. I need a new kick panel cover.
    Passenger's side mid. I REALLY need a new kick panel cover! That, and a clean way to attach the back portion to the body so it isn't sticking out so much. Since this cover is ruined already, I will experiment with a heat gun to see if I can re-shape it to sit in there better.
    The electronics. The wiring isn't perfect, and I do need to tidy up the stuff on the right.
    Yeah I know, you shouldn't have rat's nests for signal lines. It's a car...road noise dominates over anything that might come from ugly RCA cables. I don't hear any odd stuff anyway.
    The outputs. Again, it isn't exactly aircraft-grade. It works.
    Here is the sub peeking from behind the arm-rest. I do not hear any difference with the arm rest up & closed, or down & open. So, I leave it up. Any attention is bad attention in my opinion, so I like to keep this sucker as stock & boring looking as possible.
    I avoid loose articles in the trunk, for obvious reasons. I can still jam all of my climbing & camping gear in there without any worries (it might slide a little, but I can arrange it so that nothing hits the sub or the dials on the electronics.
    Yes, a hatchet, 8" knife, fire extinguisher, MAG light, various fluids, a cheap set of tools & sockets & a box of electrical supplies are necessary. For one, I drive a 20 year old German car...duh. Also, I don't like getting stuck by trees that have fallen onto the road & that sort of nonsense.
    So there it all is. The sound is very nice. I still need to swap out the 9-conductor cable for some CAT6 cable...there is a very faint bit of alternator whine present when I am revving the motor hard & whatever is on the CD/radio is quiet at that time.. It is completely unnoticeable except under very specific circumstances, and I am the only one who notices...but I still want to get rid of it. I hope you all enjoyed the pictures & story!
    Oh, and here is what I did to clean up the rear deck since I am not using the rear speakers at all.
    Transaction Feedback: LINK
    • franco90
      • 3185
      #122
      bump
      I've always been proud of being a Marine.
      I won't hesitate to defend the Corps
      "Supersquad"
      ‎"Prostitutes are a sub-category of Amusement Parks"-
      • bmwman91
        • Oct 2004
        • 3128
        #123
        I finally got this thing bumping the other day. A friend with a "system" in his Civic wanted to hear the rig. So, I busted out some Ben Folds - Rockin' the Suburbs lol. It was definitely in the 110dB+ range, because it started getting that characteristic hissing non-linear distortion sound (air behaves fairly linearly up to about 110dB re. 20uPa). If you've been to a live rock concert, you know what I mean. Damn, it is freaking sweet to know that I can get this thing p past the point of hearing damage without any audible distortion in the electronics/drivers!
        • Dozyproductions
          • Jan 2007
          • 4682
          #124
          Wow! I would really love to see exactly how the inside of the kick panels look like after your modifications. I was looking into PPI's PC3.65C set since the woofer only has about 67mm depth to it. Or at least trying to find a 6-7" driver that has shallow mounting since I have the ability to go 3 way active off the old cda - 9835.
          Since I would want to set the tweet and midrange in a fb enclsoure I was thinking of doing the same thing with the shallow woofer but just angling it a bit more on axis. The big issue of course being how tilted I can get with the space allowed in the back and getting that damn hood release a little bit farther out.
          All of this of course is smoke being blown out of my ass for now since the rest of the car deems it okay to keep breaking down. :D You truly are an inspiration for some clean looking sound in an e30. So in other words thanks for making this thread!
          • bmwman91
            • Oct 2004
            • 3128
            #125
            There isn't too much to see inside there. Basically, I pounded the back surface as far out as I could without it hitting the leading edge of the door when it is fully open (that is what limits you, and you don't want it hitting...paint will chip & you'll have a rust initiation spot). Getting the larger drivers in required me to do a lot of cutting (with tin snips) and folding of the perimeter of the existing cut-out. It is one of those "you can't go back, ever" mods.
            There is no room what so ever for angling the drivers down there. On the passenger side, the kick panel cover can come out maybe 3mm before the glove box starts binding on it. I had to cut a little bit off of the bottom outside edge of the box so it would drop. You can see the scrapes in the pics above. On the driver's side, the issue is just as bad with the knee bolster cover. Really, the drivers can't be angled.
            If you can find shallow drivers that fit the stock depth, go that route. Pounding out the pods and having the drivers sitting against the back surface is less than ideal!
            Good luck!
            • mrmckie
              • 728
              #126
              i thought an amp shouldn't be mounted upside-down because it won't dissipate the heat properly. Or is that a myth....
              "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
              1991 318is - the cruiser
              1989 325i - the rats nest
              • bmwman91
                • Oct 2004
                • 3128
                #127
                It depends. There are vents on the bottom of this one (now facing up). I suppose that the hot air inside would leak out the end plates & draw cooler air up through them. With the current setup, the opposite might happen, who knows.
                The large side vanes are still horizontal, which IMO is the most important part. The major power dissipating parts are mounted on them, and they will work better this way. Mounting an amp vertically (either orientation) will cause pre-heating further up the sink, or really poor convection on one side depending on how it is mounted.
                Truthfully though, I don't really know if this setup is better or worse. I rarely push the amp hard, so I am not too worried.
                • 5Toes
                  • 9836
                  #128
                  Woofer is in free-air arrangement? WTF
                  • bmwman91
                    • Oct 2004
                    • 3128
                    #129
                    I'd consider it more of a front-loaded baffle arrangement. The front of the sub is enclosed behind the arm rest, which is basically a super leaky damped box. The trunk is large enough, and vented into the cabin well enough that it basically all acts as one airspace.
                    Open-baffle arrangements have been used with great success in many home audio setups. This isn't quite one of those since one side is blocked (unless I put the arm rest down...but I can't hear a difference when I do). Either way, it is a perfectly "normal" driver configuration.
                    • 5Toes
                      • 9836
                      #130
                      Ill have to read up on this. I always thought open air was just crap sounding. Not tight and punch at all
                      • bmwman91
                        • Oct 2004
                        • 3128
                        #131
                        It depends greatly on the driver being used. Most car subs are designed for use in compact enclosures & suck hard otherwise. I didn't use any "car" drivers, anywhere in the car for that reason. A little know-how buys a lot of options.
                        • 5Toes
                          • 9836
                          #132
                          Oh I agree. Im doing a box for a friend, and I got my eyes on that Dayton Titanic 10".
                          It looks astonishing for the price, specs good too
                          • 5Toes
                            • 9836
                            #133
                            Just reread whole thread... why Mb Quart over say a PPI?
                            • riverdale21
                              • Mar 2004
                              • 786
                              #134
                              Sub'd
                              • StereoInstaller1
                                GAS
                                • 22679
                                #135
                                Both are hecho en china, why not? It isn't like the PPI is better...
                                Closing SOON!
                                Thanks for 10 years of fun!
