Replacement headunit options that suit the E30 interior
  • bmwman91
    • Oct 2004
    • 3128
    #151
    I saw that a couple of people were wondering about swapping the faceplate illumination on some HU's to orange, since everything BUT the lighting matches the E30 interior. It is pretty straightforward to do the swap since the parts are usually all 0805 or 0603 size. You will want LEDs with a spectral output peak at 605nm since this is the same orange that the E30 interior light filters produce.
    I have used these in the past with good success. You'll need to disassemble your faceplate to make sure that they will fit the pads where the original ones are.
    General illumination on faceplate PCB: https://www.digikey.com/product-deta...94-1-ND/637107
    LCD backlighting (some use right-angle LEDs, so these would not work there): https://www.digikey.com/product-deta...7-1-ND/2425034
    Transaction Feedback: LINK
    • earthwormjim
      • Jul 2014
      • 434
      #152
      These are the LEDs I used for the Continental head unit:
      LCD display:
      Order today, ships today. XLM2MOK11W – Orange 605nm LED Indication - Discrete 2.2V Radial from SunLED. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
      Buttons:
      Order today, ships today. LTST-C194KFKT – Orange 605nm LED Indication - Discrete 2V 0603 (1608 Metric) from Lite-On Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
      I tried that Rohm series of LEDs originally (in 0603), but they weren't bright enough. To get them to match the original Continental LED's brightness, they needed a lot of current. Too much, almost 20mA for each LED.
      • bmwman91
        • Oct 2004
        • 3128
        #153
        Hmm, yeah I suppose it depends on the HU and how the light is filtered through the buttons and stuff. I ran into the opposite problem with the RMT-200 and an old Pioneer HU...things were too bright and the Rohm ones seemed to be "dim enough" to match the rest of the HVAC panel.
        • earthwormjim
          • Jul 2014
          • 434
          #154
          The Continental was pretty easy to work on. Each LED set has a series resistor to set bias current, so you had a bit of wiggle room.
          • Albie325
            • Jul 2016
            • 515
            #155
            Originally posted by earthwormjim
            Damn that looks good. How did you go about switching the LED's? I'm a complete newb with electronics but would be willing to give it a shot if it could come out like this. The only thing holding me back (aside from ECS backorder) from ordering this head unit is the backlight color
            '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
            Albie325 Build Thread | Albie325 COTM Jan 2021
            • earthwormjim
              • Jul 2014
              • 434
              #156
              Have you ever soldered? If not, I wouldn't attempt it.
              If you have soldered, then at the very least the display backlight isn't very hard to change, it's just two T1 LEDs.
              Have you ever done surface mount soldering? If not, definitely don't try to replace the button LEDs, which are quite small 0603 sized surface mount parts.
              The radio uses lead free solder, so you need a high powered iron too, with a very fine tip.
              I posted more info here in the other radio thread:
              If you're not comfortable with the work, PM me, I'm offering the mod as a service.
              I bought my radio on ebay, I recall it being cheaper than ECS at the time.
              • Albie325
                • Jul 2016
                • 515
                #157
                Haven't soldered much, I've since watched a few youtube DIY's and it's definitely some intricate stuff. I'd really like to not ruin a brand new head unit, PM incoming.
                • e30_troy
                  • Dec 2017
                  • 85
                  #158
                  Jimmy did great work on my headunit. Highly recommend him for providing this great service.
                  • bradnic
                    • Jul 2012
                    • 3550
                    #159
                    @bmwman91 does that Conti headunit work with your RMT200 preamp boards?
                    HOWTOs:
                    DB vert plastic bumpers
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • earthwormjim
                      • Jul 2014
                      • 434
                      #160
                      I don't see why not, you would just have to find the pre-amp signal on the continental unit.
                      There's tons of open space inside of the radio too, especially if you get the non-CD version.
                      • bmwman91
                        • Oct 2004
                        • 3128
                        #161
                        Electrically, I am 99% sure that it can be made to work since these things all use the same or very similar DSP chips and stuff. Physically, I do not know if it will fit well anywhere inside. If someone has a Conti unit and is willing to open it up to post some photos, then I may have a better idea.
                        • e30RS
                          • Mar 2019
                          • 437
                          #162
                          Does anyone have an alpine recommendation for the e30?
                          • earthwormjim
                            • Jul 2014
                            • 434
                            #163
                            No aftermarket Alpine fits the E30 interior. The lighting can be made to match, but the overall design of their radios don't work. They're too busy or glossy.
                            • e30RS
                              • Mar 2019
                              • 437
                              #164
                              Ok appreciate that. Is there anything similar? Not a fan of the continental so much.
                              • earthwormjim
                                • Jul 2014
                                • 434
                                #165
                                Clarion M508 looks pretty nice after swapping the LEDs to orange or painting them orange.
                                I forgot to take pictures of the finished radio before shipping it out, but this gives you an idea of what can be done:
                                This Blaupunkt updated radio looks pretty nice too. Should be available next month.
                                A brand new and updated Blaupunkt Bremen SQR46 from Germany is the answer to all "modern tech with period look" car hifi dilemmas
