My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
    Mine just died... 9 months so far, I'll be ordering a replacement soon.
    Follow my IG @bouchezphotography
      just installed mine. I am a happy camper
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
        I am ashamed to say that I am a premature spender... I bought what I thought was a really great unit (midnight eBay goggles) prior to seeing the great reviews about the more popular choices in this thread, but have come to really regret the $35 expenditure as I am not sure what to do with it due to the instructions that came with it, which I would rate somewhere between kindling and toilet paper. Please, someone, help... This is the unit on eBay: http://www.ebay.com/itm/Remote-Centr...ht_3092wt_1107. Wire diagram below...
        I have searched and understand what wires do what in the trunk of my car, but I don't understand, based on these instructions, how to simply make my car have keyless lock and unlock without the shock of returning to my car in a parking lot and watching it burn to the ground. Again, please help...
            LOL I did this Drunk and it works...
            I've always been proud of being a Marine.
            I won't hesitate to defend the Corps
            "Supersquad"
            ‎"Prostitutes are a sub-category of Amusement Parks"-
              Can someone post a link to one? My phone isn't letting me pull it up...
                Post 40 has a link.
                  None of the links work!
                    I might have to try this.
                    1991 335is in progress
                      Goggle ---Omega REC-43T
                      EBAY------REC-43T
                        did all E30s come with power locking system? I'm not sure if I have tested mine yet with the key turned 90 deg to see if it locks all doors.
                          Turn the key see what happens.... Even my 86 had power locks
                            I got the TNTAutoTuning.com E46 Key Fob Keyless entry unit working.
                            Keyless Entry Unit: http://tntautotuning.com/store/en/re...-z4-x3-x5.html
                            This still gets installed in the trunk and still pulls 12v from the antennae motor.
                            Twist the blue and the Yellow/black wire on the Keyless Unit together.
                            Car Wire - Keyless Wire - Function
                            Brown - Black - Ground
                            Red (Antennae) - Red - Powers the Unit
                            Green/Black - Yellow - Lock
                            Green/Purple - Brown - Unlock
                            Brown - Blue &Yellow/Black - Grounding for Units internal relays.
                            Here is an atrocious picture of it wired up:
                            I have not gotten it soldered together and cleaned up yet. My buddy came over and helped me get it sorted on a lunch break.
                            Here it is all clean.
                              Have you had the key made for the ignition lock yet? If so how did it work.
                                Can anybody give a clue how to install keyless on E30 touring? I never looked the wires back in the trunk and don't know if their colors are the same as sedan/coupe. Also from where can i get constant 12V? From the trunk light must be a bitch i think. Same for ground? Thanks in advance.
                                P.S Do you guys think the trunk is the only way where i can put keyless module , because my drivers door lock mech. is fucked up, you know the problems with the lock "stick" inside the door can't get all the way down and pop up with key in lock position...
