H&R Sport Springs - Coupe Vs. Cabrio
  • spyder918
    • Apr 2019
    • 144
    So I noticed some install the H&R sport springs made for a Coupe on their Cabrios. Why is that? Is it so the rear can be lower? Here are the specs of each version that I found -
    H&R Sports for Coupe -
    F - 1.3"
    R - 1.3"
    H&R Sports for Cabrio -
    F - 1.4"
    R - 0.75"
  • e30austin
    • 15382
    That is exactly why. Coupe spring rates will be too soft for a cabrio, IMHO.
    • reelizmpro
      • 9558
      That and/or they think it makes no difference but fact of the matter is Eibach/H&R, etc. have different part numbers for E30 springs based on model for a specific reason. On the convertible with the added weight in the rear, it bottoms out regularly with standard lowering springs. With race springs the stance is even lower but at least the spring rates are much higher. I'm actually in the market for a set of H&R cabrio springs for mine.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • berndt
        • Mar 2016
        • 104
        I did the cabrio springs a few months back. No complaints.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Add me to that list...plus Koni SAs
          Alice the Time Capsule
          • spyder918
            • Apr 2019
            • 144
            That's what I was thinking too. Not sure why so many do this.
            • Das Delfin
              • Sep 2014
              • 2293
              ^ I always thought it was because they either didn't know the cabrio springs exist, or they just wanted to be low
              • stc4life
                • May 2019
                • 33
                I just did the cabrio springs, but now have more rake than I would like. I'm thinking about getting thinner spring pads - anyone else done that?
                • bradnic
                  • Jul 2012
                  • 3554
                  I used H&R convertible specific OE Sport springs. Verts are heavier.
                  HOWTOs:
                  DB vert plastic bumpers
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • funcrew
                    • Jun 2007
                    • 1223
                    Slightly off topic. I installed the H&R OE sports (the tall ones) with KYBs on my cabrio. Even with the battery moved to the trunk, it still maintains a pretty nice nose-down stance. That could be partially due to worn subframe bushings though.
                    "If the sky were to fall tomorrow, the tall would die first."
                    -Dr. Paul Forrester
                    Do I LOOK like I need a psychological evaluation???
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      If your subframe bushings we're far enough gone to effect stance, I suspect it would be undrivable
                      • PDXPeter
                        • Apr 2018
                        • 225
                        My PO had non-cabrio springs on the rear of my car and it was really terrifying to drive on the highway. Rear end was floaty and bouncy.
                        • Staszek
                          • 2533
                          The front springs are the same on the coupe and Cabrio, the rear springs are different. My car is heavier in the rear after my swap (heavier e36 M3 exhaust, bigger battery, sub, full size heavier 16" spare etc) and it was rubbing with my 225's in the rear with the coupe H&R rears when I had harder acceleration. I switched the rear to the Cabrio and it raised my rear just enough that I am now getting the rubbing and I have a slight rake that I wanted.
                          Before with Coupe rear
                          After with Cabrio rear
                          • arcpolo
                            • Aug 2019
                            • 134
                            H/R sports convertible specific springs, Koni SA
                            1993 325iC
                            1998 M3
                            1987 535iS
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              Thats what Im riding on and its perfect IMO. Hopefully your fronts are for a sedan so you can adjust them from the top
