Oil Pan Drain Plug Hole Stripped - Advice?
  • GarageBound
    • Feb 2022
    • 37
    1991 318i - Changed the oil and upon reinstalling the drain plug, it appears that the hole in the oil pan is stripped. I have tried to remove the plug part way and clean the bolt and crush washer. It still drips.
    Thoughts / advice?
  • packratbimmer
    • Dec 2009
    • 1335
    What type of crush washer are you using? Are you using a new crush washer each time?
    • roguetoaster
      Biggus Tippus
      • 7830
      Since new washers come with the filter kit one would hope.
      Two ways to fix it, drill and/or tap the pan for an oversized plug or replace the pan with new.
      Since you're clearly a novice you'll need to remove the pan to tap it so you don't end up with shavings in the engine.
      • cory58
        • 1021
        I put a Time-Sert in mine but it still dripped a little. Sourced a good used oil pan. No more leaks.
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        2015 328i - Euro Delivery/Performance Center Delivery
        BMWCCA
        E30CCA
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5611
          You can put wheel bearing grease in between the flutes of the tap to catch the metal and just pour a quart or two with the plug off and let it clear any possible remains.
          • GarageBound
            • Feb 2022
            • 37
            I appreciate the advice, not the comment. Its clear what you are as well.
            • roguetoaster
              Biggus Tippus
              • 7830
              Ask a basic question, get a response tailored to a basic skillset. Doesn't matter how old you are.
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5611
                He's a rogue toaster
                • reelizmpro
                  • 9558
                  I agree with Mr Burgandy. I don't think it's necessary to remove the pan unless you have other business like a leaky pan gasket or something. The shavings should stay localized and can be flushed out.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Probably.
                    In any case, I would personally just install an aftermarket lower pan for $20-40. But what do I know, it's not like I'm a nearly 15 year M42 fanatic or anything. I swear I'm reformed and only have an M40 these days, and they have absolutely no common components like oil pans whatsoever...
                    • reelizmpro
                      • 9558
                      ^ I didn't realize M42's had a 2pc oil pan setup and the lower pans were inexpensive. You have a good point.
                      88 M3 - LACHSSILBER
