DIY - Shadowlining
FYI don't expect to find SEM anywhere locally. One time my local oreilly had it - but I went in today and they told me they don't make sem anymore. Whatever."We praise or find fault, depending on which of the two provides more opportunity for our powers of judgement to shine."Comment
ive had the same experience. Until i went to another o'reilys in town and they had like 2 cases.....
Fortunatly theres a local parts place called Enlows auto supply. They have a massive amount of 3m products and paints. Including SEMsigpicComment
I did mine a couple of weeks ago. The previous owner had painted them but when he went to get some body work done the shop taped over it and stripped it when the tape was removed. I did it on the car and did not remove the mirrors. Here's a rundown of what I did:
- Lots of taping (painter's tape and newspaper, took my time and made sure to cover everything that could possibly catch some overspray)
- Sand back down to bare metal with 180
- Clean with rags and lacquer thinner
- Dupont etch primer (3 coats)
- Dupont trim paint (1 coat then ran out, it was a spare can laying around)
- Duplicolor trim paint (2 coats)
If it wasn't late in the evening when I ran out of Dupont trim paint I would have gone out and bought more. It seemed to be of better quality, maybe I'm just telling myself that because it's more expensive. Luckily I had the Duplicolor can in my trunk. Regardless, I am very pleased with how it turned out:
did mine yesterday.. took about 3 hrs.
~Rogan
'85 325e w/M42 swap
'02 WRX 2.5L Hybrid w/GT32 @ 20psi - 400+awhp :: SOLD
http://www.autismspeaks.org ||| http://www.essentialpieces.org
Strategic Alpine Command
Diving Board DivisionComment
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
Would you guys recommend this for grills and B-pillar as well? I'm planning on doing everything at the same time. And do I use the primer for grills/pillar or prep some other way?The best combo I've found so far is Duplicolor Self Etching Primer for $4.99 a can at Auto Zone and Duplicolot Black Trim Paint which is perfect for shadowlining your car.88 325is
