DIY - E36 window switch retrofit
  • StereoInstaller1
    GAS
    • 22679
    #301
    Can I come and steal the body controller and switches?
    I won't be able to pay for them, but will help you do something?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • franco90
      • 3185
      #302
      Luke do you own your own bussiness
      I've always been proud of being a Marine.
      I won't hesitate to defend the Corps
      "Supersquad"
      ‎"Prostitutes are a sub-category of Amusement Parks"-
      • Erick
        Official R3V Drifter
        • 11169
        #303
        Anyone ran into the color pattern I have? I'm kinda lost at this point and my harness is all cut up :p
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • StereoInstaller1
          GAS
          • 22679
          #304
          Well, kind of. I closed my shop last november, now I am just freelancing until the wife and I get settled.
          Closing SOON!
          • flyboyx
            • 8371
            #305
            Originally posted by BDSax
            i went through the shit load of e36 switch i have gotten and figured out what did what.
            E30 Switch:
            Window Up 1 - Black or (Black/Grey)
            Positive (+) 3 - Green/Grey
            Negitive (-) 4 - Brown
            Negitive (-) 5 - Brown
            7 - Black Yellow (i had this, it did nothing)
            Window Down 8 - Purple
            The e30 switch is very confusing...... there are tabs that come from the up and down leads and its always touching, im guessing it has more resistence the more it is pushed down.
            I tried to go from Power (Green/Grey) to the down lead (Purple) and it blew the curcuit. so im guessing it controlls the amount of voltage? thats what im confused about.
            n
            There are 3 different White Basee switches that i had, please check your colors. the Numbers on the switches still all lined up.
            E36 White Base #1:
            Negitive (-) 1 - Brown
            Window Down 3 - Black/Yellow
            Window Up 4 - Blue/Green
            Positive (+) 5 - Red/Brown
            E36 White Base #2:
            Window Down 3 - Purple/Grey
            Window Up 4 - Black/Grey
            E36 White Base #3:
            Window Up 4 - Green
            here is a little update on this upgrade. i started working on this swap today a found out a few things. i have the white base switches from a 4 door. i had the three wiring harnesses listed above on my plugs plus a fourth type.
            e36 white base #4
            ground(-)1 - brown
            window down 3 - violet
            window up 4 - black
            positive(+) - red/brown
            also for the e30, i have a 91 vert. as stated above, the e30 window switch has 5 wires whereas the white base e36 switches have 4 wires.
            here is how to keep them straight:(at least in the case of my car)
            there are two browns that are ground and these can be connected together to terminal 1 ground (or negative as stated above)
            all of the e30 power window wires on my car are a variation of a solid color with a colored strip. this is to say that all 4 switches have a black wire and a violet wire for the up/down function. however, 3 of the 4 have a colored stripe. the blacks are up and the violets are down.
            all four e30 switches have a green/gray wire for positive power in. these need to be soldered to the e36 brown/reds
            since my car has the power cutout button, i swapped in this switch from the 4 door e36. the e30 switch has 2 wires. both a variation of green with a stripe. the e36 cutout switch has 3 wires. two greens with stripe and one brown/red. to make this switch work, you need to connect one of the e30 greens to one of the e36 greens and the other e30 green to the brown/red on the e36 switch. the second green wire on the e36 switch will be left unused.
            Gigitty Gigitty!!!!
            • bimmer_E30
              • 5001
              #306
              can you upload the pics again, Josh?
              Originally posted by e30e
              • BraveUlysses
                • Jun 2007
                • 3781
                #307
                Seconding this, but maybe use something less shitty than photobucket, like imageshack.us instead?
                • Aptyp
                  • 6584
                  #308
                  moved photobucket folder...
                  • Wh33lhop
                    • 11705
                    #309
                    So, I hooked up a small white base (1-touch down) window switch. It illuminated, but no matter which way I hooked up the signal wires would not do crap to the window. It seems these were meant to use relays or something as the gauge of the signal wire is a lot smaller than the E30 ones.
                    paint sucks
                    • kronus
                      • Apr 2008
                      • 13022
                      #310
                      They go to the window controller module, which has internal drivers for the motors that the switches control. You won't get anywhere using just the late-style switches.
                      cars beep boop
                      • BraveUlysses
                        • Jun 2007
                        • 3781
                        #311
                        Anyone have a wiring guide for hooking up the e36 window lock switch to replace the stock one?
                        • Wh33lhop
                          • 11705
                          #312
                          Yeah, so basically extensive modification if I want to give it a shot. Then again, I wouldn't mind 1-touch windows... is it just a single module for all of the windows or do they each get an individual module?
                          paint sucks
                          • Wh33lhop
                            • 11705
                            #313
                            Uh... seriously? Both lock switches have two wires, unless you've got a crazy E36 switch that I'm not aware of, it doesn't matter which way you orient them.
                            paint sucks
                            • BraveUlysses
                              • Jun 2007
                              • 3781
                              #314
                              The E36 switch I got has 3 wires :???:
                              I guess i could just try experimenting.
                              • 2002maniac
                                • 4260
                                #315
                                Has anyone integrated the e36 one touch module? I'll have to pull out my e36 manual and look at how crazy the schematics are.
