DIY - E36 window switch retrofit
  • F34R
    sLaughter
    • 12376
    #331
    I was wondering what I would do with the e36 switches. Now I know!!!
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • Hick
      • Sep 2005
      • 6451
      #332
      I skimmed this thread, but if anyone is wondering... Radio Shack sells a light bulb that is easy to solder in to the switches.
      I changed them on my large white base switches, not sure if it will work for others, but its a good chance it will. The bulb is not colored but it gives off a light, that when installed, looks good enough to pass as 'amber'
      Microlamp #7219 12volt, 60ma
      Originally posted by vlad
      • Yeee30
        • Nov 2005
        • 799
        #333
        sweet good info. i just did mine and i need to solider new led bulbs. thanks.
        [PAKSIW]
        20D .........
        vmwerks :up:
        ryan gmw :up:
        • bimmer_E30
          • 5001
          #334
          yellow base e36 switches wont work. i burnt them rightout .
          Originally posted by e30e
            • 34847
            #335
            Originally posted by Wh33lhop
            I know, but if you could get a single module to control them all with E36 switches right out of the bat, that would be more awesome than universal one-touch modules, which typically can't use the E36 one-touch switches and just trigger if you press the switch for less than a second (significantly less cool).
            hmmmmm.... :p
            • b*saint
              • 3794
              #336
              Red X's now.
              Ma che cazzo state dicendo? :|
              • george graves
                • 20003
                #337
                Originally posted by nando
                hmmmmm.... :p
                You working on something nando?
                Originally posted by Matt-B
                  • 34847
                  #338
                  just looking, I like one touch as well. The early E36 system is really simple but the "drivers window module" thing is a bit complicated.
                  • george graves
                    • 20003
                    #339
                    Someone said that module is tied into all sorts of other stuff - would be a nice mess to sort out.
                    Anyone have e36 electrical diagrams?
                      • 34847
                      #340
                        • 34847
                        #341
                        the late module is more complicated, the early one would be easier to sort out, but only the drivers window would be one-touch.
                        • MC Hammered
                          • Jul 2008
                          • 2076
                          #342
                          I assumed that it would be driver side only as well.
                          A 4 window one touch would be a vert owners dream.
                          My 1989 e30 s52 Touring... this is Betty
                          My 1989 325i vert (sold)...this is Nina
                          My 1991 M5 (sold)... this is Veronica
                          Photo comparison: OEM vs aftermarket windscreen for a convertible
                            • 34847
                            #343
                            I think you could probably do it if you really wanted, but it wouldn't be easy at all. It's amazing how complicated the wiring got in the 96-99 E36! 92-95 is basically just like the E30, refined a bit, the late ones are something else entirely.
                            • george graves
                              • 20003
                              #344
                              I think the other problem is that the body computer is rather large - or someone way saying that it was.
                              • george graves
                                • 20003
                                #345
                                You can see the motor in the diagram. It's the little icon that kinda looks like a wrist watch and with a "M" on it. Now look at the entire unit. First thing you'll see is that the "motor" has 5 wires going to it, where ours only has 2.
                                Looks like they added the current sense resistor inside the motors rather than having them in the control unit. (?) If that's the case it won't work. No current sense on out motors so, it wont' work. (Unless you can swap motors too)
                                (They've also added a re-settable fuse - not sure if that is required. Our motors is missing that as well)
