DIY - E36 window switch retrofit
  • robrez
    • Jul 2008
    • 3376
    #376
    Here's another example of a 4-door with breaker switch console. Someone above said that the bezels would overlap, but as you can see, it's possible to finesse a good fitment with careful trimming. Blackout sold me a full set of switches and did the trimming.
    January 2012 COTM
    • Blackout
      • Apr 2011
      • 4125
      #377
      Looks awesome buddy.
      Cool ashtray too; or should i call it a change holder? since you don't smoke. :)
      » PARTS FOR SALE
      » TRANSACTION FEEDBACK
      • browntown
        • Jun 2004
        • 3524
        #378
        The coin holder is p/n 72601942786
        Joshie, can you rehost the pics for the original DIY?
        • Blackout
          • Apr 2011
          • 4125
          #379
          He probably won't. I have asked the same question, just so that the DIY would make sense. May be i can help you out. What is the issue?
          » PARTS FOR SALE
          • browntown
            • Jun 2004
            • 3524
            #380
            no issue, actually the new zealand how-to ( http://www.bimmersport.co.nz/forums/...hp/t30907.html ) is pretty well laid out. Was just thinking that DIY's could be easier for newbies to use.
            The josh/andrew article is mirrored here: http://strictlyeta.net/technical/e36switches.html the links just need to be updated in our diy.
            • e30F
              • Jul 2011
              • 12
              #381
              It's so much easier with pics.
              Browntown - thanks for the links!
              • crazyman
                • Dec 2010
                • 738
                #382
                Thanks to BDSax and flyboyx I was able to finish my wiring. I was starting to pull my hair out Cus the pig tails I got with the switches were different colored wires then most of the write ups I had seen.
                85 swartz/metallic 325E
                84 alpine 325E
                85 zinnoberot 318i/R.I.P
                84 Bronzit 318i/sold
                purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
                • e30vert
                  • Jan 2005
                  • 1789
                  #383
                  Anyone know where to get replacement LED bulbs and resistors as is shown in the picture here My Blue base e36 switches have LED's and are fine. My white base have incandescent and they are burnt out and I just want to solder in a set of LED's and resistors.
                  Any info is appreciated.
                  • Killacortes
                    • 1937
                    #384
                    Pics aren't working :(
                    r3v does not fuck around. First you get banned, then they shoot you
                    • Blackout
                      • Apr 2011
                      • 4125
                      #385
                      Radioshack.
                      » PARTS FOR SALE
                      • glucklich21
                        • 1912
                        #386
                        Those are factory LEDs, not RadioShack.
                        • browntown
                          • Jun 2004
                          • 3524
                          #387
                          Well crap, I'll have to add led replacement to my list. So I source this kind of stuff from the local electronic supply house (not radioshack if I can help it) or just order from digikey.
                          Anyone know the specs of the oem bulbs and resistors? My guess would be a 5mm red led (which run around 2v). So you would then take the difference (12v-2v=10v) and divide by .02 (20ma) = 500 ohm resistor right? Match to wattage and you should be good to go.
                          I'm sure George or Luke could tell us for sure.
                          • e30vert
                            • Jan 2005
                            • 1789
                            #388
                            Well done! Although since all diodes (including Light Emitting Diodes) drop .7 volts then I would imagine that .7 should be subtracted and not 2 volts. Also 5 mm LED seems way too large for the space that the original OEM LED mounts in though. More like 1 mm or perhaps 2 mm . Its a small area. Perhaps George can chime in. Paging George ...
                            • e30vert
                              • Jan 2005
                              • 1789
                              #389
                              -1988 e30 vert wiring for e36 switches
                              Just finished sorting out all the wiring for my e36 switch installs.
                              Used 2 Large White Base e36 Switches for the front and rear driver side windows
                              2 Large Base Blue Switches for the passenger side front and rear windows
                              Here is a picture of every wire combination used to make these work.
                              18 total wiring connections needed to be correctly installed for all the switches to work!
                              Next I may install aftermarket one touch boxes so that I can drop all the windows with one button.!!!!
                              • AndrewBird
                                The Mad Scientist
                                • 11897
                                #390
                                So, reading back over my wiring test DIY, I honestly have no idea what I was talking about, so let me simplify a bit.
                                There should be 4 wires essentially on each switch, power, ground (possibly 2 wires), window up and window down. At rest (no buttons pressed), the window up and window down wires are grounded and therefore, are connected to each other and ground. When a button is pressed, either the window up OR the window down wire is connected to power and is also disconnected from ground.
                                Some switches have more then 4 wires, but two of them will be ground. The e30 is like this, they have 2 brown ground wires.
                                Start out by finding the 1 wire on the switch that doesn't connect to the other wires when nothing is pressed. This is your power wire and connects to Green/Grey in your e30.
                                Next, connect one end of your meter to the wire found in the previous step and while pressing up on the switch, find which wire has continuity. This is the up wire. Do the same with down.
                                The remaining wire(s) is/are ground. Verify this by checking continuity between it/them and your up and down wires you found earlier. You should have continuity with no buttons pressed and should never have continuity with the power wire.
                                Here is the e30 wiring, as posted before in this thread:
                                Power - Green/Grey
                                Window Up - Black
                                Window Down - Violet
                                Ground - Brown (2 wires)
