DIY - E36 window switch retrofit
  • moatilliatta
    • 6121
    #76
    Werd. They were $1.04 each.
    i got them for free:grin:
    @Zakspeed_US
    • Jand3rson
      • 37587
      #77
      Congratulations. You didn't get them for free from the dealership, which is where I was talking about.
      • moatilliatta
        • 6121
        #78
        nope. not from dealership.
        @Zakspeed_US
        • vt.bimmer
          • Jan 2006
          • 844
          #79
          Ok, Im going nuts here. I wired the switch up exactly as pictured from all the DIY stuff that I printed and the only thing I can get to happen is the window goes down. Here is a pic of how they are connected.
          WTF am I doing wrong. I used a test light to see where I was getting power. With the key turned and not pressing anything the green/green wire lights up. When I press the switch for the window to go down the greenblue to brown wire lights up. Nothing else lights. Ive tried switching them around a bit and got nothing one time and another time when I turned the key the window just started going up. Im confused. Hep a brotha out! Please??
          • AndrewBird
            The Mad Scientist
            • 11897
            #80
            The links to the wiring diagrams don't work anymore, so I can't look to see if you wired it correctly. Let me check when I get home though, I have the files on my home computer. :up:
            • vt.bimmer
              • Jan 2006
              • 844
              #81
              I would appreciate it. I hooked them up according to the pics on the strictly eta tech write up. Im trying to get this done tomorrow.
              • erik325i
                • Jan 2005
                • 3567
                #82
                Just so you know, you can't wire them up by wire color because each e36 switch does not use matching color wires.
                -Erik
                • dude8383
                  • Jan 2005
                  • 10387
                  #83
                  yeh that write-up confused the shit outta me. heres how it should wired up
                  Green/Blue = Green
                  Black = Black
                  Blue/Green = Brown
                  Black/Yellow = The other brown
                  Blue = Purple
                  Im going to check the way i wired everything up just to be on the safe side.
                  I'm pretty sure this is how its supposed to be wired up.
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    #84
                    Green/Blue = Green
                    Black = Black
                    Blue/Green = Brown
                    Blue = Purple
                    This is correct and SHOULD work. See pic below.
                    • vt.bimmer
                      • Jan 2006
                      • 844
                      #85
                      Actually thats exactly how I have it wired in my pic.
                      • vt.bimmer
                        • Jan 2006
                        • 844
                        #86
                        -Erik
                        I have the same exact colors on my blue base switches and e30 harness as the strictly eta write up.
                        • dude8383
                          • Jan 2005
                          • 10387
                          #87
                          try reversing the brown wires...and also check the fuses.
                          • vt.bimmer
                            • Jan 2006
                            • 844
                            #88
                            Hmm, I tried that too. I didnt get a chance to mess around with it today, but I loosely hooked up the old switch to roll up the window and it worked fine. Fuses are OK.
                            Is it possible the switch is fucked?
                            • dude8383
                              • Jan 2005
                              • 10387
                              #89
                              that could be a possibilty...i mean if you have everything wired up correctly and the fuse is good. lol i doubt it could be anything else but the switch then..
                              • soliver
                                • Feb 2006
                                • 40
                                #90
                                If anyone is interested in using the sunroof switch I just put them in. Lights up and works great.
                                E30 - E36
                                Browns - Brown
                                Green - Red
                                Purple - Black
                                Black - Green
