DIY - E36 window switch retrofit
  • golde30
    • 11464
    #121
    Originally posted by NitroRustlerDriver
    IIRC, there was an extra brown wire on the switch that we did not connect. I am thinking now that this wire is the wire for the light.
    yeah there was an extra wire for me too, i just connected the 2 brown wires together...
    IG: @Baye30
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      #122
      i went through the shit load of e36 switch i have gotten and figured out what did what.
      E30 Switch:
      Window Up 1 - Black or (Black/Grey)
      Positive (+) 3 - Green/Grey
      Negitive (-) 4 - Brown
      Negitive (-) 5 - Brown
      7 - Black Yellow (i had this, it did nothing)
      Window Down 8 - Purple
      The e30 switch is very confusing...... there are tabs that come from the up and down leads and its always touching, im guessing it has more resistence the more it is pushed down.
      I tried to go from Power (Green/Grey) to the down lead (Purple) and it blew the curcuit. so im guessing it controlls the amount of voltage? thats what im confused about.
      E36 Blue Base:
      Negitive (-) 1 - Black/Yellow
      Window Down 3 - Blue
      Window Up 4 - Black
      Positive (+) 5 - Green/Grey
      Negitive (-) 6 - Blue/Green
      I think that the blue/green ground is the stupidest thing i have ever seen
      There are 3 different White Basee switches that i had, please check your colors. the Numbers on the switches still all lined up.
      E36 White Base #1:
      Negitive (-) 1 - Brown
      Window Down 3 - Black/Yellow
      Window Up 4 - Blue/Green
      Positive (+) 5 - Red/Brown
      E36 White Base #2:
      Window Down 3 - Purple/Grey
      Window Up 4 - Black/Grey
      E36 White Base #3:
      Window Up 4 - Green
      I havent tried hooking up any switches yet, but i tried the Green base switch. it didnt work except the bulb lit up.
      Every switch i went through had a blown bulb. so if your bulb isnt working its because its blown. im going to change mine to LEDs, i think these little POS bulbs suck. i will be installing mine soon. i hope this helps some people
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        #123
        First Open up the switch. should look like this
        Yes, that black thing in the middle is the bulb.
        Bulb should look like this..
        POS Bulb
        Rip out the old bulb
        Tear out the plastic bulb holder with a pair of skinny needle nose
        All I had was whire LEDs and some old resistors around. bend your led - lead like so. it will fit on the top bar going acrossed. the positive will hook up on the bottom part.
        Solder on your Resistor on the + (down below) then solder on the - (up top)
        Make sure the Positive and negitive on the LED isnt touching anything. Tie the other end of the Resistor to the positive of the LED. Make sure you snip your ends so nothing touches.
        Mine will shine White, but i dont care, i think it should look good at night. Ill take a pic at night when its in the car.
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          #124
          I think the white leds look better than the orange.
          and to clear things up, you can use the switches any where. i made a tail and it works everywhere and plugs right in.
          • dude8383
            • Jan 2005
            • 10387
            #125
            holy shit man, thats awesome! i may consider doing the whole LED replacement.. it looks relatively simple. Is the rocker switch fragile or can it be taken apart easily?
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              #126
              its easier to take these e36 switches apart then it is the e30 switches.
              • moatilliatta
                • 6158
                #127
                this could change things big time... what if we do led's in the insturment cluster????////
                @Zakspeed_US
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3594
                  #128
                  man, im thinking about it. LED's never burn out, and they are brighter!
                  • Addiction2E30s
                    • Jul 2006
                    • 171
                    #129
                    Finished mine up the other day. I have not seen any pics of this done in a vert or 4 door, so thought I would post my pic. I had to use a center console from an e30 w/o power windows. The original console had the switches to close together, the e36 bezels would have overlapped.
                    • JDMpower
                      • Sep 2006
                      • 1771
                      #130
                      I pulled some yellow base e36 window switches from a 318ti today - will these work for the swap?
                      Thanks,
                      Josh
                      '89 "is" = M technic II build mode.
                      • BDSax
                        Junkyard King
                        • Mar 2006
                        • 3594
                        #131
                        as long as they arent a 1 touch. if it has a really small connector, then its not good. they just blow the fuse
                        • JDMpower
                          • Sep 2006
                          • 1771
                          #132
                          They have a pretty small connector...I will take a pic...
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3594
                            #133
                            doesnt sound good. i tried to hook them up and they would just blow the fuse. maybe is a resistor is hooked up.
                            • JDMpower
                              • Sep 2006
                              • 1771
                              #134
                              Here is a pic - if this one will not work, it will be posted now anyway! LOL EDIT: part # 61 31 8 368 941
                              • BDSax
                                Junkyard King
                                • Mar 2006
                                • 3594
                                #135
                                nope, you need the large base switches. usually found on the sunroof. and sometimes the rear door on the older e36s. i may try hooking them up with a resistor. that may work.
                                problem is that is you touch just the wires together to try an make the window go up and down, the fuse blows. its weird. so the switches that work must has resistence or something
