The Detailed E30 R-134a Conversion Thread/DIY
  • netcsk
    • Apr 2004
    • 1609
    #301
    1.8 pounds is perfect for my completely redone system on an s52 and parallel flow condenser.
    • xcx4x
      • Sep 2013
      • 184
      #302
      OC peeps with experience
      ill be blunt:
      anyone in the OC that has done this conversion willing to do the same for my car? ill be there as a hand and pay $$ for your services
      • varg
        • May 2014
        • 3288
        #303
        Just wanted to chime in and thank everyone who contributed useful information in this thread. It was very nice to not have to play the information-hunting game as I begin to restore my AC to working condition and make sure the R134 conversion was done right. It was an especially pleasant surprise to have information relevant to the 318is compressor right on the front page.
        IG @turbovarg
        '91 318is, M20 turbo
        [CoTM: 4-18]
        '93 RX-7 FD3S
        • funcrew
          • Jun 2007
          • 1223
          #304
          Does anybody know the part number and/or size for the smaller of the 2 o-rings on the condenser? 1991 E30, the diameter of the metal the o-ring slides onto is 8.75mm. None of the o-rings I ordered from this discussion thread fit correctly. Pelican parts does not list an 8-and-change-ish mm a/c o-ring. Next smallest available is 7.65mm. Please advise.
          "If the sky were to fall tomorrow, the tall would die first."
          -Dr. Paul Forrester
          Do I LOOK like I need a psychological evaluation???
          • varg
            • May 2014
            • 3288
            #305
            7.64mm according to: http://www.e30tech.com/forum/showpos...19&postcount=2
            O-rings are supposed to have a stretch fit so it's ok that it's a mm and change smaller.
            O-ring info
            The A/C system is built with SAE sized hoses and connections.
            BMW lists o-rings by I.D. in mm, vs standard sizes or dimension
            Thus a #6 o-ring, which is 3/8" or 9.525mm, is listed by BMW as 7.64mm
            O-ring count and locations
            7.64mm 4 (both liquid hoses)
            11.1mm 4+1 (hot vapor hose, expansion valve liquid out, press. switch)
            14mm 1+1 (expansion valve vapor, EV adjustment)
            17mm 1+1 (compressor inlet, compressor manifold)
            Expansion valve and evaporator, 17/19/22/24mm wrenches
            One 7.64mm #6
            Two 11.1 mm #8 x 1/16" I.D.: 11.1mm O.D: 14.3mm T: 1.6mm
            Two 14 mm #10 x 1/16"
            (Fifth o-ring is for the superheat adjustment plug)
            ETK lists 11.1 and 14mm (602/603) for evap side of exp valve
            Compressor
            64-50-1-468-464 11.1mm for outlet (see high pressure hose)
            Either
            64-50-1-468-466, 17mm (19x17mm) (3/4", #12) for Bosch inlet
            or
            64-50-1-468-465, 14mm (#10) for Denso inlet
            Condenser
            64-50-1-468-464 11.1mm for inlet (high pressure hose)
            64-50-1-468-463 7.64 for outlet (hose to drier), 17/19mm wrenches
            Drier
            64 50 8 390 601 Two 3/8" (#6) o-ring for tube fittings
            64 50 8 390 602 One 1/2" (#8 ) o-ring for pressure switch
            Note: For two pressure switch drier only. Switch with wire leads
            is pipe threads, pronged switch is o-ring sealed. New style drier
            uses a combined pressure switch with a Schrader valve connection.
            Firewall
            Liquid connection 17/19mm wrenches
            64-50-1-468-463, 7.64mm (3/8", #6)
            Vapor 24/27mm wrenches
            O-ring count: 5X #6, 5X #8, 3X #10, 1X #12
            64-50-1-468-463, 7.64mm (3/8", #6) new part number for '601
            2@ drier, 1@ tube connection, 1@ E.V., 1@ condenser outlet
            64-50-1-468-464, 11.1mm (1/2", #8 ) new part number for '602
            1@ drier switch, 2@ E.V., 1@ compressor, 1@ condenser inlet
            2@ E.V., 1@ tube connection, 1@ compressor suction (late compressor)
            64-50-1-468-466, 17mm (#12)
            1@ E.V., 1@ compressor suction (early compressor), 1@ Bosch manifold
            Hoses:
            High pressure hose (64-53-8-391-052), compressor to condenser:
            Two 64-50-1-468-464 11.1mm
            Behr $62.75, German $69.81
            64-53-9-067-572 High pressure liquid hose, condenser to drier
            64 50 8 390 601 Two 7.64mm (3/8", #6) o-rings (?)
            $93.20/$74.56
            Liquid hose, drier to expansion valve:
            64-53-1-380-094 metal tube, and 64-53-8-391-047 interior tube
            Metal tube to 9/87 only
            Vapor hose, evaporator to compressor
            64-53-8-391-048 interior vapor hose
            64-53-1-377-821 exterior vapor hose assembly R12
            64-53-8-391-051 exterior vapor hose assembly R134a
            64-53-1-380-542 heat exchanger
            R12 $109/$86.14
            R134 $151/$141.91
            IG @turbovarg
            [CoTM: 4-18]
            '93 RX-7 FD3S
            • isaacneedshelp
              • Nov 2014
              • 8
              #306
              So I tried ordering my condenser using the link provided a couple of weeks ago (said there were still a couple in stock) well 2 weeks later I finally called Amazon to find out they are out of stock. Called another website trying to buy the same part, they tell me it's on back order for a "2-3 months". Phoenix will still be hot for the next 2-3 months so does anyone have a suggestion on where I can go to find this or any kind of alternative?
              • dude8383
                • Jan 2005
                • 10387
                #307
                RockAuto has a few in stock. I bought 3 for customer cars.
                CLICK FOR LINK
                • rjmcdermott81
                  • Oct 2014
                  • 563
                  #308
                  I just wanted to add this note about swapping the o-rings on your condenser without taking apart the whole front end. I just had my car painted, so the less body pieces I touch the less risk of scratching/denting something.
                  I'm not changing my compressor but just needed to put the A/C lines back in with new o-rings. I found that, with a little bit of patience you can put the A/C lines on by only taking off the front right grill around the headlights.
                  Image with grill out (just two screws and three clips):
                  Close up on access to the hose that goes to the compressor:
                  Access the line that goes to the dryer through the slits in the front valence:
                  Close up....this one was a pain, but it only took a few minutes
                  Build Thread: Ryan's Hennarot 318is
                  COTM Aug 2019
                  • efficient
                    • Feb 2012
                    • 3312
                    #309
                    One question when you add the r134a hot and low side fittings on the original valves do you guys take Schrader valves out ?
                    • Klug
                      • Sep 2011
                      • 804
                      #310
                      I replaced mine- they are dirt cheap to replace (don't forget to get the little tool) since most of the older schrader valves leak over time.
                      The new r134a side fittings have a pin that depresses the Schrader valve when the R134 valve is hooked up- so you leave them in there.
                      555Garage - Kingston, PA
                      '13 BMW e70 X5 35d
                      '95 BMW e34 525i
                      '92 BMW e30 325i S52 Vert (Quade the Vert)
                      '92 Range Rover Classic
                      '90 Range Rover Classic
                      '89 BMW e30 325i Coupe (The DIRTY30)
                      '81 VW MK1 Rabbit Caddy Diesel
                      '76 Honda CB550K Cafe/Brat
                      '67 Pontiac LeMans
                      '24 Model T Depot Hack
                      ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
                      • efficient
                        • Feb 2012
                        • 3312
                        #311
                        I wonder if it makes a difference if I just put the new adapter on the r12 thread, I found out its missing the r12 Schrader valve.
                        • JinormusJ
                          • 6887
                          #312
                          APDI 7013464 condensers are out of stock everywhere
                          Just when I was finally ready to pull the trigger
                          • efficient
                            • Feb 2012
                            • 3312
                            #313
                            I bought the one from the link in the first post, mine came silver.
                            • spiftacu1ar
                              • Jul 2015
                              • 17
                              #314
                              Does anyone know an alternative to the condenser listed on the first page? As JinormusJ said, they seem to be out of stock everywhere.
                              • deeclue
                                • Jul 2015
                                • 92
                                #315
                                I'm also looking for another condenser option. Anyone know of one?
                                EDIT:
                                After reading this entire thread I found that most people were saying to use the Nissens one on autohausAZ. Aamzing what reading the whole thread will do for you :-)
