Originally posted by cory58
View Post
The Detailed E30 R-134a Conversion Thread/DIY
Originally posted by 808ETA View Post
Thank you Cory! My dryer says 64101 however the box has the same PN and it looks the same. I'm going for it!
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCA
I get asked often enough about AC that I wanted to share this. It explains rather clearly why using a manifold gauge to figure out when you've pulled a proper vac is an exercise in futility. The difference between 500-1000-1500 microns is a hairs width on the dial.
Alice the Time Capsule
Originally posted by 808ETA View PostGot everything buttoned up and system recharged!! Thank you again for everyones tips and help!
1988 320i Touring
2000 M5
1977 530i
BMWCCA
E30CCA
Thought some of you might be interested in the compressor that i put on my m20b23. I couldn't find an oem r134a compressor in Australia for less than about $1600 aud....
So I used a Sanden SD5H09 gineric R134a compressor, that only cost me about $330 AUD brand new. You can get them with the V belt or the ribbed belt, obviously get the V belt one. probably even cheaper in the USA.
I made my own bracket as the oem compressor has a really long nose on it and the Sanden is significantly smaller than oem. In heinsight i should have made the bracket so the compressor sits slightly lower as it does make the CAS very hard to remove (i have an m20b25 CAS - megasquirt)
I then had to modify the hard lines - you can see where i TIG welded on a new fittings to the hard lines (after cutting off the rubber bit) - these were called "bulk head connectors" for AC lines. Then just got some hose and fittings and made new lines to suit - these from were a vintage AC shop - really quite cheap and easy to make - supplied with a crimping tool. excuse my welding - first tig project - but it doesn't leak!
The rest of the r134a conversion was same as specified, i did just re-use the r12 condensor. seems to work fine. New TX valve and dryer were pretty cheap and then I just put new R134a orings everywhere. got it gassed a month or two ago, and works quite good and the sanden is very quiet, hardly tell its on.
I have since put a bit of heat protection on that AC rubber line - but its not as close to the exhaust as it looks in the photo.
Apologies for the photos uploaded weird.
Since I had was replacing everything with new parts I decided to sent my A/C compressor out to be rebuild. It was working fine however I didn't want to have a weak link in the system and have to go in there again. Mike from Discount A/C was very informative and rebuilt it in 1 day. Shipping wasn't bad either as it fit in a USPS medium flat rate box. Total cost was $172 including shipping, insurance and pulley bearing replacement. They also have good prices on new and rebuilt A/C
http://www.discountautoac-compressor...or-C20804.aspx
sigpic84 325e
Originally posted by noid View PostI don't know why anyone struggles with converting to R134a, just run R12a.
Per the FrostyCool website, I used 11oz of their R12a refrigerant to charge the E30 system that calls for 2.1lbs (+/- .05) of R12. For equipment, I used some manifold gauges, R134a conversion fittings and a two-stage vacuum pump - all off Amazon. I left my existing dual pressure switch setup in place as well as the stock expansion valve. I'm still playing with things so I'll report back with more concrete data on pressures and things like that. I thought I may have overcharged the system so I vented some refrigerant out and now I believe it's under-charged again as my idle vent temps went up to 52*F and cruise vent is 37*F. All of this is on factory R12 parts namely the condenser (fin/tube not parallel flow).
I had another E30 325iX converted to R134a about 10 years ago and that car performed admirably; however, I really think sticking with the R12 system (tube and fin condenser), replacing the dryer and all the o-rings is the correct solution for these cars. Based on my research, I'm just not concerned about running a hydrocarbon-based refrigerant either (a common argument against R12a). It is unfortunate that the EPA hasn't approved this as a replacement for R12 systems as it is better for the environment than even R134a (which is no longer in favor anyway as everyone is switching to R1234yf or whatever it is).
I think people are making more of a deal out of the "Conversion" than it requires. it all comes down to if you need a new compressor or not. if the old compressor works fine then theres no issue with just staying with r12 or the modern equivalent. if you need a new compressor then you might as well go for an R134a one. And if you are going to the effort of changing the compressor you really should get a new dryer (cheap), and you might as well get a new TX valve while you have no gas in it (also quite cheap). And then all new o'rings are worth nothing and it wasnt that big of a deal to swap them all out. Pressure switches don't cost much at all to get a new one. And as mentioned i just used the original R12 condenser and evaporator. the car is so small that the loss of efficiency i don't think matters so much. of course if you need a new condenser or evaporator then get an r134a one.
You USA guys seem to be able to buy the refrigerant very easy, here in Australia you cant even buy gas without a refrigeration license, so it costs $200 minimum to get gas put in, so i made sure to get it all new so as not to need more gas down the track if something leaks etc.
- Likes 1
I had a bit of a setback. I couldn't for the life of me get the low-side pressure to come up at all. Would stay around 5-8psi - high side was ~150psi. The vent temp was exceptionally cold but after 30-40 minutes of driving, the vent temps would start to increase to low-mid 50's (F). I'm pretty sure the evaporator core was freezing up (also noticed fan performance wasn't quite as good and sounded a bit different. Without being able to see in there, I'm just guessing. The thought is the thermal expansion valve (TXV) is hung up and not metering flow well enough which is causing very low temps but eventually ending in an ice-over condition. At this point I've ordered new hoses, TXV, o-rings, dryer, low switch, high switch and a new tube/fin condenser to get to a point where I know what I have. I'm also poking around trying to sort out the parts necessary to run through the compressor as well. There is a guy over on mye28.com that rebuilds them but I'd prefer to try it myself if I can.
