DIY - Double to Single Fuel Pump Conversion
  • LBC28730
    • May 2020
    • 58
    #31
    Just to add to this thread: I did the TRE conversion and the first pump very quickly dropped to 18psi.
    TRE was good about it and sent a replacement.
    That pump also failed after a short time but thinking it was another issue, I didn't drive the car for a while and by time I got back around to it, it was too late to get another replacement.
    Guess I'll be going with the walboro pump this time
    • reelizmpro
      • 9559
      #32
      Just make sure it's an actual Walbro! Many sellers will use name "Walbro" as a keyword. They might use terms like "Walbro replacement" in the fine print. Even use the Walbro part numbers, it's very deceptive. Same thing with Spal fans and Bosch injectors....too many fakes out there on ebay.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • 82eye
        • Jan 2009
        • 2109
        #33
        are you running turbo or modified?
        a 90's 6cyl mustang pump runs the same pressure as the stock bmw single pump. it's a very wallet friendly diy alternate. been fine in my car with mild mods. just won't work for turbo or heavy mods.
