Before & After Bumper Tuck Pics?
  • jerods87e30
    • Jun 2007
    • 226
    #91
    Had a question-
    I tucked my front bumper on my '87, and of course there is that damn gap between the top and sides of the bumper and the bumper apron/covering. The black bumper covering is a little warped on one side as well, but nothing too severe.
    I had thought about using black silicone (actually, if done right, it wouldn't matter the color) to adhere the bumper cover to the top of the bumper. I think I'll try it, but, the sides will still stick out and I don't know how to overcome that problem. It's just that the bumper itself tapers from the back to the front hence the empty space after the tuck.
    Give me your opinions. Thanks
    • threlevenguy
      • Dec 2006
      • 1057
      #92
      check a few posts ago about washers.
      • E_DIRTY
        • Nov 2007
        • 39
        #93
        i noticed only one of you guys is still running fogs. does keeping the fogs limit how much tuck action you can get into?
        • eyagel
          • Jan 2007
          • 756
          #94
          probably, i have an IS valence, and it is like perfectly lined up with the lip, i dont think there is very much space there.
          • DaveSmed
            • Apr 2007
            • 1407
            #95
            Not sure about everyone else, but I removed mine simply because they are ugly.
            If you wanted to keep them, i'm sure you could. Worst case scenario would involve drilling a new hole or enlarging the existing mounting hole in the bumper IF it interferes.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • sharksforthecup
              • Aug 2007
              • 246
              #96
              How the hell did you guys tighten the nuts back on the bolts where the screws for the bumper go through the bumper shock flange? I can't fit my hands in there. I was able to get a nut on one screw for each side by hand, but that was all(I can't tighten it down because my wrenches won't fit in there either. Do I have to cut my way in there?
              thanks in advance for any input
              • Mr.sexymorningvoice
                • Sep 2007
                • 402
                #97
                what took me the longest on the whole project was bolting the front bumper back up...with it on our lift and whatnot it was still a PITA, but i ended up using a 1/4in drive ratchet, a wobbly 3in extension, and a swivel socket, and a lot of hand cramping.
                • Wishno87
                  • 6025
                  #98
                  that took me the longest too. i ended up extending the shock just long enough so that i can fit my hand in there to tighten the nuts then pushed the bumper in by hand.
                  • StereoInstaller1
                    GAS
                    • 22679
                    #99
                    Wait...did you guys pull the front bumper to tuck it?
                    Fuck all of that.
                    I jacked my car up, drilled a 1/4" hole in the bumper shock (making sure to get none of the spew on me), shoved it in, measured it, and shot 1/4 X 1 1/2" screws in it.
                    Done!
                    Closing SOON!
                    Thanks for 10 years of fun!
                      • Sep 2007
                      • 402
                      #100
                      why did you put screws in it? i thought about it...like maybe some small bolts. but it didn't seem to be goin anywhere
                      • StereoInstaller1
                        GAS
                        • 22679
                        #101
                        2 reasons: One, the rear bumper scoots around while I am driving. Not much, but I wanted no movement at all.
                        Second, with the early "is" lip, I did not want 100% tuck on the front. I am in most of the way, but not all, so my lip lines up 1" behind the bumper. I liked the look better.
                        I also bolted the lip to the bumper so sag is not possible, no matter how much I scrape the fucker.
                        Luke
                        Closing SOON!
                        • Wishno87
                          • 6025
                          #102
                          hey Luke when am i going to get to see what you did to those ebay tails?
                          • StereoInstaller1
                            GAS
                            • 22679
                            #103
                            Shit, man...who knows. They are sitting in the same box they came in....
                            Closing SOON!
                              • Sep 2007
                              • 402
                              #104
                              Luke
                              cool beans...wanna show it of a little, sounds like it looks pretty good
                              • StereoInstaller1
                                GAS
                                • 22679
                                #105
                                Sure...
                                That is the only pic I have on my home PC to show here...sorry.
                                Luke
                                Closing SOON!
