Shift Lever and Short Shifters
  • Janissarie
    • Sep 2007
    • 211
    #391
    thank you guys
    I got in contact with Patric at BMA and he hooked me up with the z4 3.0 lever
    Jani
    • rThor432
      • Feb 2007
      • 3907
      #392
      Originally posted by Janissarie
      thank you guys
      Jani
      How much did that run you?
      • gearheadE30
        • Jun 2007
        • 3734
        #393
        The whole kit with some new bushings is $75. I just bought the kit along with some other parts and a z4 2.5 lever. I've heard that the 3.0 can be a bit difficult as a daily driver or if your synchros are bad.
        Project M42 Turbo
        • rThor432
          • Feb 2007
          • 3907
          #394
          Ok just wanted to check and see if my price was decent. I got my M coupe shifter with all new bushing, washers, etc for $53. For some reason I thought that price seemed a bit off.
          Guess not.
          • mikeinboise
            • Aug 2007
            • 11
            #395
            Guess not.
            Where did you buy this at?
            • rThor432
              • Feb 2007
              • 3907
              #396
              The dealer. I'm friends with the parts manager. He's a good guy.
              • *R*
                • 230
                #397
                I bought a Z3 Mcoupe shift lever and i just installed it without bending the selector rod. I know that bending the rod will eliminate the rubbing on the harmonic balancer, but will it reduce the notchiness? It actually takes alot of force to get it into gear
                http://www.collegehumor.com/video:1726949
                Originally posted by 92 mtechnic cabrio
                gross, I bet that has an offset so positive it could prove to eliminate all emo feelings
                • Majikal
                  • 518
                  #398
                  no, that notchiness will still be there. If you just installed it, give it a week or two before you change your mind. It will loosen up a bit. It will still be notchy, but not quite as much.
                  • rThor432
                    • Feb 2007
                    • 3907
                    #399
                    You dont have to bend the selector rod, just eliminate the balancer. It is worthless.
                    • *R*
                      • 230
                      #400
                      Is it really? taking something off of the car just seems a bit sketchy. so does bending something on it.
                      • thereisnoyun
                        • Feb 2007
                        • 2301
                        #401
                        You are installing somethign that didnt come with the car. I would just bend it. Taking the balancer seem to be a 50/50 with some people. Some people have vibration after taken off the balancer. I would just do the simple bend and get it over with.
                        • rThor432
                          • Feb 2007
                          • 3907
                          #402
                          It's fine without it. Hell my '87 eta didnt even come with one from the factory. No problems, but whatever.
                          I personally dont like the idea of bending something and compromising it's strength.
                          • brandondan1
                            • 1091
                            #403
                            I installed the UUC EVO3 kit with DSSR last week, and it's great! It removed all of the slop that I was experiencing with the stock 20yr old parts. Throws are short, but not too short, and notchiness is kept down to a minimum. Neutral and in-gear play is greatly reduced as well.
                            If I had to compare it to a new car, it's very similar to the g35/350z 6MT gearbox, except a bit smoother. Just what I was hoping for in all honesty.
                            Worth 400 bucks? I think so, if you want to have the a shifter that feels like something out of todays sports cars. Can't wait to see how it feels with MT90 the tranny
                            91 318is
                            • digger
                              • Nov 2005
                              • 6206
                              #404
                              is installing the UUC EVO3 more time consuming?
                              • Dozyproductions
                                • Jan 2007
                                • 4682
                                #405
                                So i ordered the Z3 2.8l shifter and just had Rob try to install it. Well, the damn thing didn't clear in my car. I have an 89' 325i manufactured in 10/88.
                                I think shifter was clearing in the normal gears but just scraping the harmonic balancer in reverse. (i believe)
                                You guys have any suggestions or thoughts on this?
