Shift Lever and Short Shifters
    • 34847
    #406
    uh, take out the harmonic balancer? it's really not neccesary..
    • Dozyproductions
      • Jan 2007
      • 4682
      #407
      So why is it there?
      • Jean
        • 18228
        #408
        So why is it there?
        It's not even installed on all e30s, so it's safe to remove it. This has been covered many times too :)
        • Dozyproductions
          • Jan 2007
          • 4682
          #409
          yeah i realized that after searching for a bit :)
          I will consider it though thanks.
          • Erick
            Official R3V Drifter
            • 11169
            #410
            FYI, Ireland Engineering has reported that they were actually seeing pre-mature wear on their higher HP cars that kept the harmonic balancers. They run all their cars without the balancer now.
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
              • 34847
              #411
              So why is it there?
              so the yuppies BMW was selling cars to in the '80s wouldn't complain about NVH.
              • rThor432
                • Feb 2007
                • 3907
                #412
                Ding ding ding. Correct.
                • Dozyproductions
                  • Jan 2007
                  • 4682
                  #413
                  not to discredit anyone because it really really isn't my intention. But how do you guys figure this out? I mean was there some specific testing done for these conclusions or the fact that it's some what known that the "known function" of a harmonic balancer is just merely hearsay?
                  • rThor432
                    • Feb 2007
                    • 3907
                    #414
                    Only 1 out of 3 of my transmissions came with the HB. All of them are mated to M20 6-cylinders, so no difference there.
                    The small guibo 260 in my '87 iS came with the HB installed. My big-guibo'd 260 and 245 tranny didnt have balancers. Both came from the factory without balancers.
                    That's how I determined that it wasnt important. If it didnt have it from the factory, then it must not be important. I took it off my standard 260 as well, all I had to do was grind the hell out of a deep socket to make a custom thin-wall.
                    • Erick
                      • 11169
                      #415
                      I have been running my car without a harmonic balancer for 10k miles and the track car for 20 track events+
                      Normal wear.
                      Ireland Engineering builds and races many cars, and I took what they said based on their likely experience. :)
                      Feedback Thread
                        • 34847
                        #416
                        because some of us have been modifying e30s for 5-10+ years and have been down that road already.
                        • Dozyproductions
                          • Jan 2007
                          • 4682
                          #417
                          Normal wear.
                          Thanks for the input.
                          I haven't been down that road thats why im asking the question on a forum. Ive checked a lot of threads, and knowingly probably missed a bunch, and pretty much everyone explains it like you. You trying to explain to me to why i shouldn't have my HB is like an episode of Lost. Frustrating to listen to and then left with 40 more questions after your done.
                          I get that your trying to help me and your opinion along with some other people's experiences is making me consider in taking it off.
                          • naika
                            • 466
                            #418
                            Originally posted by e30prideTN
                            Well I should be newer and I just placed the order with Patrick...http://www.bmaparts.com/item.wws?sku...entid=bmaparts
                            He said this should be all that I need unless I find anything else within it that needs replacing.
                            Total w/ discount...$69!! Now off to find a knob.
                            Is this kit equivalent to using an OEM Z3M shifter? What do you guys recommend as the best choice (and not too expensive either)
                            Thanks
                            344is! Obd1 conversion
                            • naika
                              • 466
                              #419
                              just got a kit from BMA
                              Hi,
                              I just called BMA and ordered the Z3 2.8 kit. My question is, do I have to buy a new Selector rod joint and guide pin? Or can I simply buy the washers and bushings to rebuild the selector rod?
                              Thanks
                              • bimmer_E30
                                • 5001
                                #420
                                whats the best for the ETA??
                                Originally posted by e30e
